Hello everyone I think I need to build a relay box, but I am not sure.
I need to take an eagle tree Eagle eyes Antenna tracker and connect it to a Vicon v390Apt pan and tilt head. photos and documents. The eagle eyes controls normal pan and tilt with a servo sending out a pwm signal on 5volts.
The Vicon V390APT uses 115v at about .65a to control the head, the original joysticks were controlled by momentary switches and the head rotates. I believe that the diagram below is a diagram of the controller but I am not sure. when the joystick is released the switch opens which leaves the camera at that position.
I believe that the motors are steper motors.
so how can I get this to work together? I need to have the head pan and tilt depending on the imputs from the pwm servo signals so that it is automatic.
Is there anything out of the box that could be used? if not how do I go about building this.
Please let me know, Thanks
