how fast is a scr turn on time ( general )
rick_337nm
Joined May 31, 2023
6
thank you..no product, want to try to use as a spark gap replacement--if i hit the gate pretty hard, the series stack of 3 is expected to be around 200-300 peak amps and discharging a few hundred pf-- hoping it to be sub microsecond
...probably have to build/ test it but thought to post/ ask here
...it is for exciting a transverse discharge laser
schmitt trigger
Joined Jul 12, 2010
2,258
GE’s SCR Manual addresses this concern exactly: which is how fast the SCR reaches its minimum holding current, the forward conduction voltage drop and the actual gate sensitivity.
The subject matter is complex enough for the book to warrant a full chapter. 30 pages total.
EDIT, there are 2kA continuous conducting SCRs available. You don’t require to go through electrical hell attempting to parallel several devices.
rick_337nm
Joined May 31, 2023
6
...yes, thank you ( 1972 print )- the current squared/time for damage apears to be thermal and the low energies involved and the parasitic resistance should prevent this i think- in the application intended ( hopefully to get nitrogen to lase ) it should be at least fast enough for a co2 laser ??
