How does this work?
AnalogKid
Joined Aug 1, 2013
11,056
How tall is the large black rectangle in the center of the receiver board? It might be a reed relay, in which case the white and yellow (or green) wires go to a single "Form A" contact set, which is SPST, normally open. The contacts close upon receipt of a valid signal.
ak
NoviceChris
Joined Aug 11, 2018
22
I have put a voltage tester on all cables when active.
Sensor activated:
Positive to green = no output
Positive to white = no output
Negative to green = no output
Negative to white = no output
Green to white = no output
Sensor in standby:
Simple talk please as I don’t know jargon or acronyms
What I want to achieve is a simple switching function. (Break the sensor = switch on)
ericgibbs
Joined Jan 29, 2010
18,873
hi Chris,
There will be no voltage output.
A pair of contacts are closed when active.
Do you have a resistance Ohms range on your test meter.??
E
ericgibbs
Joined Jan 29, 2010
18,873
hi,
So when you measure the Ohms and then activate the receiver by pointing the transmitter at it, the contacts should close and the resistance meter reads almost zero Ohms when activated and greater than say 100K Ohms when not activated.
Can you check that out.?
E
Dodgydave
Joined Jun 22, 2012
11,307
Sensor activated:
Sensor in standby:
Ensure Jumpers J1, J2, are set the same on both transmitter and receiver,.
Put jumper onJ3, put power on, measure between Green/White it should read short circuit, when the unit receives a valid code signal, the relay operates and Green/White becomes open circuit .
Remove J3, and the Green/White are reversed, ( open circuit until a valid code received ).
NoviceChris
Joined Aug 11, 2018
22
hi Chris,
Try these two circuits.
One for resistance and one for a voltage output.
Do the Ohms test first.
E
Ohms read 1 when connected to white and green when transmitter is off (bream is broken) and drops to 0 when transmitter is on (bream is active and connected)
I’m guessing that means it’s an open circuit when beam is not broken?
NoviceChris
Joined Aug 11, 2018
22
I’m sorry I don’t understand the jumper, j1,2,3 stuff? Can you explain so a 5 year old would understand. What is it for?
LesJones
Joined Jan 8, 2017
4,191
The jumpers select the frequency that modulates the transmitted infra red signal in the transmitter. In the receiver the jumpers select the centre frequency of the bandpass filter. If the transmitter is set to a different frequency to the receivers filter then it will not be recognised. The option to select different frequencies is so that units working close together do not interfere with each other. Think of it a bit like radio stations transmitting on different frequencies. You only receive the one that your radio receiver is tuned to.
Les.
NoviceChris
Joined Aug 11, 2018
22
Les.
The same as using a radio transmitter for an alarm or similar when you select the codes by turning on/off the numbered switches.
What does nc/no mean?
sghioto
Joined Dec 31, 2017
5,392
No. When the beam is not broken it's a closed circuit.
SG
