IMO the relay contacts will give sufficient isolation for your project.The initial plan is just a low voltage 12v (max) device. If safe, maybe 120vac
I will do that. If I do not get to it tonight, will not be until end of weekend. What do you hope to figure out from this data?hi tru,
If you would like to investigate this problem a little further, will you please measere the 6 voltages marked A, B,C, D, E,F relative to the Gnd pin.?
Apply +5v to the Inp terminal while measuring the voltages, keep the jumper links in place.
hi tru,
Let me know what you measure.
E
