drjohsmith
- Joined Dec 13, 2021
- 1,662
That crystal is a long way away from the ic.and capacitors ..that's where the random caps itsncd is likely to be ..In about 12 hours (I'm guessing) the pic circuit is about 1 second fast with 32pf (10pf in parallel with 22pf) loading capacitors on the 32khz crystal.
That will also introduce drift as it will vary as your hand is near it ..
I'd use an oscillator instead of the crystal / resonator ,
