How do I interface audio amp to key encoder
Papabravo
Joined Feb 24, 2006
22,082
There are a number of people who post nonsensical questions that extend to hundreds of posts and are largely a waste of time. The TS/OP never seems to read any of the replies and keeps the thread going as some kind of twisted exercise. This whole thread is also going nowhere on the other board where it is posted and I'm guessing that will be it's fate here as well.
rogs
Joined Aug 28, 2009
279
That thread you have mentioned has been completed by me over ten months ago. Without required help from any one else who posted there. And working 100% the way I need it to work.
I had to work on it until I got it working without further help. And no one on that thread new how to solve the problem.
But I did. Go figured that? And I'm not even an engineer. I'm only fourteen.
As others can read, I posted many suggestions to try and help you on that thread. For the most part you ignored the advice, and resolutely refused to post an audio sample, to try and help identify your problem....
In addition, people can also read that I personally posted a working sample that showed that my suggestions did work. You weren't really interested.
In the end, you simply ignored the final request for an audio sample, and just went away......
As you say, you are only 14. And, it would seem, not a very polite 14 year old.
In reality, more likely to be a troll, as Papabravo has already suggested....
Nykolas
Joined Aug 27, 2013
115
+1 rogs!
I wasn't going to get involved in this! This is a technical forum and anyone here should try and state in clear logical form a question or answer. The OP failed: F-! And, if this is the English grammar, sentence structure and punctuation they taught you in school, your teacher should be let go!
Cheers and good luck! E
