EDIT: Purpose for the circuit is that turning off and on the PSU's switch doesn't reset protection mechanisms.Purchase a N.C. PB ?
I want to keep the PS_ON and GND always shorted and only disconnect them to reset protection mechanisms. (My PSU has a switch).Not completely sure what you want achieve?
I only have normally open buttons.Why would a normally closed pushbutton switch not work?
yesDo you have any relays?
Where are you from? A NC Push Button costs less than $2. With shipping, it’s less than $10.I only have normally open buttons.
inverter gate.I want to make a "Reset" button for my repurposed ATX PSU that cuts the jump between PS_ON and GND when pressed (to reset protection mechanisms). How do I do so?
A piece of duct tape can hold it down.Use a spring to keep the N/O switch pressed. Then add a lever to pull the pushbutton upwards against the spring.
Hint: a N/C switch is probably cheaper than a spring.
But won't it lose its stickiness after a few operations?A piece of duct tape can hold it down.
Only if you use the cheap stuff! But the way I see it, if we are going janky we might as well go full jank.But won't it lose its stickiness after a few operations?
