How cheap it's possible to a build an LCD Clock Now?
28,243
Given that the cost of the original clock was in Rupees, the source of the original components was probably not the suppliers that I am familiar with. And given the towering inflation that has been inflicted on much of the world today, even the "friend's" effort could not be duplicated.
However, certainly a clock sort of assembly could be made from used components if the "second user" market were adequately exploited. But it would demand a fair amount of expertise to accomplish, AND the resulting creation would be a One Of A Kind item not easily duplicated.
So it does not seem likely that the original effort can be outdone, or even matched.
Unless the TS is a MASTER OF RECYCLING.
Shafty
Joined Apr 25, 2023
358
Hi All,
Sorry, was a bit late for this reply. (My friend needed my laptop for 2 days). Anyways, Cheaper or Costly. I have decided to start my project. Please list out the things to procure:
Hope you all are with me for this project. Please Help. Thanks in Advance.
With Hope,
Shafty
drjohsmith
Joined Dec 13, 2021
1,650
Hi All,
With Hope,
Shafty
the first thing is to identify your priorities
things that come to mind
is it a one off
is it just for you
is it for a demo or constant usage over many years
is it to be wearable, or to be a stand alone
what power source do you envisage, "mains" , battery ,re chargeable, PV, one time battery
Is it to be readable all the time
is it to be read by you , or by many people at a distance
what accuracy do you want
what actual cost do you want
what is your time scales
what support do you have
what equipment do you have to hand
Sorry, from the different comments so far, its just us speculating what you want.
Ya’akov
Joined Jan 27, 2019
10,295
Hi All,
With Hope,
Shafty
You'll have to provide a specification to work out a design before you can compile a bill of materials.
"The cheapest LCD clock possible" now can be expensive? You never explained what you mean by "to build", you have not specified a set of functions (except 'always on" and 12- or 24hour format. "Always on" has no clear meaning in this context as you can see from the thread, and the format is immaterial to the basic design.
You will need to be far more specific if you actually plan to make something and hope to get help here.
Shafty
Joined Apr 25, 2023
358
is it a one off - No
is it just for you - Yes
is it for a demo or constant usage over many years - Constant Usage
is it to be wearable, or to be a stand alone - Standalone
what power source do you envisage, "mains" , battery ,re chargeable, PV, one time battery - Rechargeable battery is also okay
Is it to be readable all the time - Yes
is it to be read by you , or by many people at a distance - Only by Me. (2 Meter Radius is enough)
what accuracy do you want - Has to be visible from 2 meters away
what actual cost do you want - Cheapest possible (Upon reading the replies, I have increased my budget. 250 Ruppee if Not 300 Max)
what is your time scales - 24 Hours (AM/PM not required)
what support do you have - Self confidence :)
what equipment do you have to hand - A Laptop
Shafty
Joined Apr 25, 2023
358
I just need a clock to glance at.
drjohsmith
Joined Dec 13, 2021
1,650
what parts can you get / have for free ?
accuracy, how many seconds per day are you prepared for it to loose / gain
Given the cost requirement,
have you considered a wooden clock,
I've seen a few made out of old "tea chests" and off cuts of ply wood,
would not be LCD, but the requirement seems to be flexible,
Shafty
Joined Apr 25, 2023
358
Dear Me
Dear Doctor JohnSmith,
Thanks for supporting me...
I can get a soldering machine. (My Dad has it)
As my Home is located in the heart of the city, I can get electronics spares also cheaper.
If started,
Will sleep only after finishing the project. That is my dedication level.
Form factor should be very tiny
Shafty
Joined Apr 25, 2023
358
I'm sorry but we just aren't communicating. Good luck with your project, I hope it is successful.
Sorry. I was having my lunch. That's why not able to explain it properly.
Something like the above is okay. You know, a wired display standing on the wire itself. And some other paper block to not make the battery move. As simple as that.
28,243
If the TS does not own "a soldering machine" than my guess is they also lack fine soldering skills and experience. Without that skill it does not seem likely that any design could actually be built. That includes the suggestion for attaching a larger display to a cheap electronic LCD watch.
Shafty
Joined Apr 25, 2023
358
No Mister Bill, I can do it!
drjohsmith
Joined Dec 13, 2021
1,650
Can someone atleast list out the components to procure?
With Hope,
Shafty
you need a display
you need a means to drive that display
you need a means of calculating the time
you need a means of powering
a fair bit of wire,
a fair bit of experience in wiring up,
probably a scope and volt meter for testing and know how to use them
