How cheap is too cheap?
Ordered a few sets of these online from China. I knew they wouldn't be high or even standard quality but twisted wires for the probe connections? That's mighty low bucko.
I'd prefer it to the typical cheapo work with cold jointed solder globs. Least now you can put a clean joint on them.
I'd rather have a crimp connection than solder so the connection won't break as quickly during use but that will work here.
DickCappels
Joined Aug 21, 2008
10,661
When these grabbers came out sometime around 1980 we always cinnectef the leads by wrapping them around the center and sometimes add a twist or two. This made it very easy to maintain the leads.
Soldering the wires creates a stress point at junction of the solder filled wire and the silder free stranded wire causing early failures.
I do not remember having trouble with unsoldered connections and I still use this method today.
jpanhalt
Joined Jan 18, 2008
11,087
I don't know to whom the OT comments were directed. My post was directly related to the TS's desire for a crimped connection. This solution is easy to do, does not require disassembly of the grabber for crimping, and is fully insulated once assembled.
It's not about your good post.
DickCappels
Joined Aug 21, 2008
10,661
The topic of this thread broadly relates to grabber clips mentioned through most of the thread. A post on a completely unrelated subject taking the thread into a completely different direction was deleted and the poster politely asked to post that information elsewhere.
I apologise for any offence taken.
The topic of this thread broadly relates to grabber clips mentioned through most of the thread. A post taking ghe threat into a different firection was deleted and the poster politely asked to post that information elsewhere.
Really?:D Grabber clips was just one example of a possible many others before it was short circuited by possible clairvoyant powers about future example postings.
