I said that when you compress a gas, it heats up. This is the principle of the Diesel engine.
If it heats up, it will lose some heat to the environment..
But let's assume compression so fast that it doesn't have time to lose heat to the environment, i.e. adiabatic.
Adiabatic mechanical work depends on the temperature difference
https://en.wikipedia.org/wiki/Coefficient_of_performance
So the temperature difference is in the denominator.
When the denominator tends to zero, COP tends to infinity.
That is, with a small mechanical work you bring a lot of heat.
The efficiency of a heat engine = mechanical work/heat received.
I don't understand something........
Something is not connected regarding theoretical notions and practice.....
Why am I having this discussion and why am I saying this?
Maybe there is an idea that can be put into practice to improve the performance of a heat pump?
Edit: I did not find a group on the Internet that discusses thermodynamics and theory and practice
Many only discuss theoretical problems of thermodynamics, probably for grades at school.
Others build engine mods and are not interested in theory too much.
