MaxHeadRoom
- Joined Jul 18, 2013
- 30,693
I suspect that the PWM is input on the pin of the same name, and the opto is used to isolate from the mains fed controller.
Max.
Max.
How do I figure out what to input to the pin?I suspect that the PWM is input on the pin of the same name, and the opto is used to isolate from the mains fed controller.
Max.
There have been others that have used a similar circuit for PWM input controllers.
You need to do a little more checking as to the terminal strip, does the VDD and +15v have any voltage on them? IOW is this supplied on board or fed externally?
Also the other side of the diode input to the opto you mentioned, see if this comes out to the outside terminal.
Without having the board in hand it is difficult to do this at a distance.
Max.
I have this board and the motor with wiring, I am trying to adapt it to a 12" atlas lathe.This controller requires a pwm input and valid feedback from a front roller and the motor encoder attached to the controller.
Hi All.... Well, I must say I am glad to hear of the PWM drive for speed control. When folks want to simply add a pot to control speeds, they should understand the meaning of hot-grounded drive circuits and see why it's a bad idea to try the pot added to a point inside this hot-grounded drive circuit. Most controllers run these hot grounds, which requires the opto-isolators for passing speed and fault commands to and from the hot side to the common grounded or cold side on most controllers made by DCI for many fitness manufacturers.Anybody?
You may be better off sourcing a KB drive off ebay for your lathe motor.Anybody?
Hello IamJatinah,SJED08089IF
