ICON MC1648DLS ZE0824 Treadmill Motor Control Board Console wiring interface
imalearnin
Joined Oct 7, 2022
13
I am trying to repurpose a treadmill motor and motor controller on a treadmill with a trashed console unit. The controller is identified as an ICON MC1684DLS ZE0824. The motor itself seems fine running on a battery but I am needing some help with the wiring of the controller board. A photo of the board is attached along with a couple of zoomed in images.
I am trying to identify the 9 wires going to the (10 pin) connector. The wires go to the console. I don't see any identification on the board itself and if I look at the board on the console all it says is "treadmill". Gee that is a big help, ha ha.
I am assuming the red and black are power but I have no idea what the other wires do. Does the UPT and DS mean anything to anyone? There are 2 VG on the other side.
My thinking is that if I can identify the wire's purpose then I and produce the signals using an Arduino or some other method to create PWM or other signals as needed. I would just love to see a schematic with the connections identified but have been unable to find one on the internet.motorcontroller.jpgmotorcontrollerwiring.jpg
Connector at the console
Any help would be greatly appreciated.
MaxHeadRoom
Joined Jul 18, 2013
30,808
I have some knowledge of the MC2100 series but none on this one, I'm afraid.
But if similar, the board DC supplies are on the main board typically it has a 12v DC supply for the console where the second processor is located.
To run as a separate unit, all that is required for the MC2100 is a 50Hz PWM signal.
This signal enters the board through a 4-pin opto-isolator 817, etc.
The red & blk would typically be the supply for the console.
Some tests of the 10pin connector may reveal something.
Together with a little reverse-engineering.
Blue is the PWM signal on the other version.
imalearnin
Joined Oct 7, 2022
13
I will be on the lookoutto see if I can pick one up for reverse-engineering, maybe do a swap for a working MC2100 ! ? ;)
Thanks, I have figured out a little bit but not a whole lot. The U and D pins are for the incline motor up and down and I got that working ok.
There are 2 reds (one striped) with 12 volts and 2 blacks (one striped) that are ground. (marked V and G)
That leaves P, T, and S pins.
I was thinking P might be for PWM. I tried putting 12 volts on that pin (100% duty) but nothing happened. I fiddled around with the others and still got nothing. I am wondering if one of the pins is to enable/disable the controller for safety or something.
Actually I have no clue and am not 100% sure the board works but I was told it worked before the console got broke.
I also tried tracing wires at the console but they all go into another circuit board and I can't follow anything.
The
P pin has light blue wire
T pin has green wire
S pin has purple wire
if those colors mean anything to you.
MaxHeadRoom
Joined Jul 18, 2013
30,808
12v is not going to cut it, if it requires PWM. !
Is there any sign of an opto similar to what I indicated the MC2100 has?
Also, I assume the board has a processor IC on it?
imalearnin
Joined Oct 7, 2022
13
Thanks for the info. I am not sure about the opto. I hope I didn't fry it with my playing around. I will continue to try and figure it out.
jps80
Joined Dec 2, 2025
The
I'm working on this board now as well, not sure if you found your answers, from what I found T was for "tach" the speed sensor and the violet/purple wire on S was the incline sensor. supposedly either 0 or 5 VDC
khaledl
Joined Dec 30, 2025
Hi Jps80,
any success? i have the same issues , lost the consol when an update was launched. now before ordering a new MP10 Argon screen ,i wanted to make sure that the rest of the treadmill is functioning/ my controller board is ICON ZE0824. i can't determine the pins PST which is the pmw . and probably there is an enable some where.
i am pretty sure the board is good but it is the matter of the correct singnals to the correct pins.
thanks
