Greetings. I understand that many others have had issues with the MC1648DLS motor controller. I've personally noticed when the board temperature rises above 120 degrees Fahrenheit, the board seems to stop the treadmill motor. I've been able to mitigate this by installing a CPU fan directly underneath the board. None of the components on the board have burned out or need to be replaced. I'm just struggling with the overheating issue.
Has anyone had success directly replacing the heatsink with something better? I'm interested in modifying the cooling solution in a way that I can reassemble the treadmill with minor external modifications.
I've attached a photo of the board for those not familiar with this motor controller.
