how can i convert 24v to 12v?
CornyCorn
Joined Feb 13, 2016
12
Hello, this is my first post so please bear with me.
I am 12 years old and i am working on a prototype for an invention i have. I will need to turn 24vdc into 12vdc, but i want to use something that:
-will not generate heat
-that is small in size (about an inch)
Thanks!
panic mode
Joined Oct 10, 2011
5,041
you can make voltage divider using two same value resistors. but you will quickly find drawbacks to this if you need significant current. in that case switching regulator is what you need.
dl324
Joined Mar 30, 2015
18,393
Welcome to AAC!
Don't want to discourage you, but what you want to do is not possible. Even the most efficient regulator will generate heat.
CornyCorn
Joined Feb 13, 2016
12
Perhaps you are being too critical. He is 12 years old and not a crusty old fart like you.
@CornyCorn What is your definition of "will not generate heat"?
I apologize for being vague. i already have a transformer to 24v. I need to step down 24 volts to 12, power a few components, and then step it down to 5 to power some more components.
Also should I have the voltage stepped down to 12v then 5v or should I have 24v stepped down to 5v then stepped up to 12?
What's your advice?
Thanks
hp1729
Joined Nov 23, 2015
2,304
What's your advice?
Thanks
24 Volts, 12 Volts and 5 Volts at how much current. Power (E x I) will determine the method you use to a big extent..
dl324
Joined Mar 30, 2015
18,393
If you specify your current requirement(s), you'll get more appropriate suggestions.
Alec_t
Joined Sep 17, 2013
15,125
If you don't know the current requirements, at least tell us what the 'few components' are that you will be powering at 12V and at 5V.
Incidentally, 1" is just one dimension. What are the other dimensions?
Evanguy
Joined Dec 21, 2014
94
A simple buck converter should work for you. there are some circuits on google or they can be had on ebay for about 2$ i assume you will be drawing less then a few amps. some even with led screens to show output as they can be varied
CornyCorn
Joined Feb 13, 2016
12
Are there any models that you recommend? I prefer to have ones with PCB pins.
hp1729
Joined Nov 23, 2015
2,304
7812 for 12 V. Same circuit but 7805 for 5 V. Actually only the regulator is needed. The caps and stuff are not mandatory, depending on the rest of the circuit. Even with a small heat sink you are looking at about one cubic inch.
GopherT
Joined Nov 23, 2012
8,009
He said no (little) heat. Now you recommend a part that works as a voltage regulator by purposely converting the excess (VxI) as heat? That poor little 7812 will dissipate 24-12volts of voltage drop = 12V and then 12V x 2 amps = 24 watts of heat. Try again.
dl324
Joined Mar 30, 2015
18,393
The current draw will be around 1-2 amps.
A 5V linear regulator would dissipate P = IV = 2A*19V = 38W. You should use a buck (step down switching) regulator to minimize power dissipation.
They sell switching regulators that are drop-in replacements (PCB hole pattern only) for LM78xx regulators, but they're relatively expensive and probably won't handle more than 1A.
ScottWang
Joined Aug 23, 2012
7,503
Did you see the current he needed -- around 1-2 amps?
hp1729
Joined Nov 23, 2015
2,304
Good point!
He could possibly put together a switching regulator. One of the "Simple Switchers". You trade complexity and cost for heat and cheap.
