How are wires secured into electrical applicance/product?
dl324
Joined Mar 30, 2015
18,465
From data sheet, it seems for part (QFG-16200) the hole size is 10mm if you look at top right entry for that part.
I didn't look at that table, but hole side for the part number you gave is 10mm. I have no idea why they started putting metric dimensions in brackets while the ones on the left are in inches.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Thanks. From data sheet, it seems for part (QFG-16200) the hole size is 10mm if you look at top right entry for that part.
That part in itself does not offer good retention, there is usually plus some other means such as the saddle etc I showed.
The grommet type typically offers prevention of damage due to flexing only.
Reloadron
Joined Jan 15, 2015
7,940
Can someone recommend a good grommet for this product? https://www.digikey.com/en/products/detail/tri-mag-llc/L6R12-180/7681522
As you can see, the grommet hole has to clear the 10mm barrel jack diameter but after that it's a typical thin wire. I'm looking for a flexible grommet I guess that would allow clearance of the 10mm diameter but is otherwise small.
You linked to a common wall wart using a common barrel jack. DC output, standard 5.5 x 2.1 x 9.5mm corded dc output plug right off the data sheet. Just use a mating connector like these or just use a bulkhead connector. If you want to use a grommet just look at your cable diameter and find a suitable grommet. These are among the most common DC connectors out there.
Ron
jai.whitey
Joined Oct 19, 2021
16
Ron
Thanks for the reply. I'm using the wall wart with this power barrel jack connector on my PCB (https://www.digikey.com/en/products/detail/cui-devices/PJ-036AH-SMT-TR/1530971). So I still have to feed the wall wart wire into my product to the PCB, so I will need a grommet I believe.
For the grommet, it's a bit tricky since the hole has to clear the 10mm barrel jack diameter at the tip, but the rest of the wire is the typical thin wire. I believe a product such as this one would work: https://www.amazon.com/HYCC-2-3-Fle...a2907&pd_rd_wg=mHcdi&pd_rd_i=B01HT2VKN2&psc=1
panic mode
Joined Oct 10, 2011
5,245
it all depends on application. this means considering type of wire/cable (solid or flexible), bending radius, environment/seal rating etc.
a good strain relief grip cable, provides seal, protects cable from sharp edge or flexing at one point.
these types are very low cost and easy to use. just drill a hole and attach strain relief. price per entry can be $1-$10 depending if plastic or metal.
djsfantasi
Joined Apr 11, 2010
9,237
Or have you considered removing the jack from the PCB and replacing it with one on the exterior? Then, you can wire it to the PCB with wire and a connector.
panic mode
Joined Oct 10, 2011
5,245
when there is plenty of cables to pass through enclosure wall, or if there is an issue preventing cutting/reassembly of cables, there are entry systems that handle that too:
Ian0
Joined Aug 7, 2020
13,278
The law requires that the cable must not pull out if subjected to a force of 60N.
My method of testing is to put a piece of tape in contrasting colour around the cable where it enters the product. The attach a weight to the plug (a bag of ball bearings), then use the product to lift the cable and weight off the ground.
Repeat the number of times required by the standard, then look at the tape to see if it has moved.
28,256
I wish that they would do that with laptop computers. When the power connector is just soldered to the mother board, possibly surface mount only, but even thru-hole is poor, one bump on the power connector and a solder joint fails and becomes intermittent at best. And getting at the area to service on that one HP computer was 23 pages of dis-assembly instructions and 24 pages to put it back together.
