How Are Surge Protected Jumper Leads Constructed?
dazza111
Joined Jul 6, 2011
HI
I was looking for a source of cheap and easy to get thick cable to connect up some car batteries in parallel and I thought I would explore jumper cables as a possibility. I have found that they are selling Surge Protected Jumper cables now and I am wondering if there is a device embedded somewhere in the cables or the aligator clips that does the job. And would I need to remove the surge protection for my purposes.
dazza1
dl324
Joined Mar 30, 2015
18,427
Welcome to AAC!
That's one way. I have jumper cables that separate in the middle so that you can put one pair on the battery and it will indicate whether polarity is correct.
The new Lithium jump starters often have electronics in the leads to deal with surge and reversed connection.
You could search for information on the cables.
It depends on your application.
