We have a Horizon T101 treadmill and out of nowhere it stopped working without the controls turning on. We replaced a Rectifier IRFP260NPbF (It looked burned out) and the controls panel turned on. The incline motor works with the controls panel, the speed buttons work but when you hit the go to start the treadmill the motor makes a noise and then get the famous "E1" error. So we tested the motor and it worked. Any ideas on what might be the next step? I have attached images after we replaced the Rectifier but I personally dont see anything.
