I have Honda heated grips on my motorcycle. The heating function works, but the LED does not light up when the heating is turned on. I have conducted some measurements myself and connected the controller to a lab power supply, but I cannot simulate the setup. Also, I cannot measure/find some points on the PCB. The gray wire is the power supply for the control. The green wire is ground, and the blue wire controls the LED. The LED has been tested with the lab power supply and it works. When I measure the voltage from the controller to the LED after pressing the button, it is 0.4 volts. It should be 5 volts. Can someone give me some help?
