Comments:
1) The 2N3772 is certainly a beefier transistor than the 2N3055, but note the darlington driver and compare with my reservations about the BD140 driver in the earlier post.
2) Note the substantial cooling arrangements.
3) I liked the 'plastic pot of spares placed inside the case', though one then wonders about the author's confidence.
4) This supply is earthed at the negative terminal. You cannot use it as a floating supply as implemented.
5) Sorry Bertus but I didn't see control all the way down to zero.
Voltage Output in 'Low' setting is variable from 0.7 - 6 volts (more later why the 0.7V), in the 'High' setting the voltage is variable from 3 - 30 volts. Current is adjustable in the 'Low' position from 0 - 1 amp and in the 'High' setting from 1 to 10 amps.
