Home Assistant devices and uses
How do you know that China does not have direct access to everything in your home through that thing?
I assume you're not talking about the old Chinese type 53.
Because I control my network using a DL360 server firewall that I installed, configured and monitor. It's not WiFi ,Thread is local IPV6 in the ULA range.
It can't talk outside my local network and everything else is local private IPV4 subnets (some for sensors, some for clients, etc...) from a a IPV4/IPV6 dhcp server and a local DNS for system names. I've only one public IPV4 that's uses NAT on the firewall. I get lots of network probes (we all do) and am notified if something is persistent or triggers my bad guy IP list. The firmware updates are not hosted in China.
https://manpages.debian.org/testing/arno-iptables-firewall/arno-iptables-firewall.8.en.html
https://en.wikipedia.org/wiki/Unique_local_address
A unique local address (ULA) is an Internet Protocol version 6 (IPv6) address in the address range fc00::/7.[1] These addresses are non-globally reachable[2] (routable only within the scope of private networks, but not the global IPv6 Internet). Because they are not globally reachable, ULAs are somewhat analogous to IPv4 private network addressing. However, there are also significant differences, as each user of ULAs has a unique address range, whereas IPv4 private addressing is common to many users. Unique local addresses may be used freely, without centralized registration, inside a single site or organization or spanning a limited number of sites or organizations.
Industry usage
The ULA block is useful in the context of service providers and content providers, as it provides isolation of the infrastructure and hence avoids exposure to the Internet.
One such example is Amazon Web Services, which uses ULAs within its virtual private cloud networking. In particular it uses the block fd00:ec2::/32 for local services, such as time sync services or DNS resolvers.[10]
I've also moved all of the Orange Pi Soc DAQ boxes to the latest Linux mainline aarch64 kernel (7.4-rc2 as of today) and replaced the OEM destro software with arm64 Debian Sid to be sure all of the security updates are being used as they are published.
