Home Assistant devices and uses
Something so simple!
This is why I build my own stuff. It's trivial to include UTC time stamps with each data sample for time synchronization on controllers without accurate time keeping.
"RDAQ1name": "Energy_Mqtt_BMC1",
"RDAQ1board": "BMCBoard",
"RDAQ1sequence": 5893,
"RDAQ1mqtt_do_16b": 1,
"RDAQ1mqtt_di_16b": 0,
"RDAQ1bmc_adc0": 4.9963909422158626,
"RDAQ1bmc_adc1": 3.7562726511828224,
"RDAQ1build_date": "Jun 22 2025",
"RDAQ1build_time": "09:42:01",
"RDAQ1sequence_time": 1750699594
"RDAQ2name": "Energy_Mqtt_BMC2",
"RDAQ2board": "K8055 (VM110)",
"RDAQ2sequence": 15006,
"RDAQ2mqtt_do_16b": 32,
"RDAQ2mqtt_di_16b": 0,
"RDAQ2bmc_adc0": 31.283194167450276,
"RDAQ2bmc_adc1": 30.052978542849083,
"RDAQ2build_date": "Jun 12 2025",
"RDAQ2build_time": "08:47:14",
"RDAQ2sequence_time": 1750699594
"RDAQ3name": "Energy_Mqtt_BMC3",
"RDAQ3board": "BMCBoard",
"RDAQ3sequence": 586,
"RDAQ3mqtt_do_16b": 2,
"RDAQ3mqtt_di_16b": 0,
"RDAQ3bmc_adc0": 25.227795128151275,
"RDAQ3bmc_adc1": 31.475574896633365,
"RDAQ3build_date": "Jun 22 2025",
"RDAQ3build_time": "09:42:01",
"RDAQ3sequence_time": 1750699601
C:
* check for incoming data on the MQTT connection
* use UART1 or the MQTT receive data port
* calc_bsoc runs in interrupt low context and uses 16-bit results -> git_power from this
* cmd_value is the buffer variable
void gti_cmds(void)
    static uint8_t value[] = {0, 0, 0, 0}, vi = 0;
    static uint8_t utc_value[DEF_TIME_SIZE] = {0};
    static bool utc = false;
    uint8_t vcmd_size = sizeof(value);
    uint8_t utc_vcmd_size = DEF_TIME_SIZE - 1;
    if (Sready()) {
        mqtt_r = Sread();
#ifdef GTI_ECHO
        UART1_Write(mqtt_r); // debug echo
#endif
        switch (mqtt_r) {
        case '0':
        case '1':
        case '2':
        case '3':
        case '4':
        case '5':
        case '6':
        case '7':
        case '8':
        case '9':
            if (!utc) { // process power cmds
                if (vi < vcmd_size) {
                    value[vi++] = mqtt_r - 48; // ascii '0'
                } else {
            } else { // process UTC time from host cmds
                if (vi < utc_vcmd_size) {
                    utc_value[vi++] = mqtt_r;
                } else {
            break;
        case 'T': // begin UTC value
            utc = true;
            break;
        case 't': // end UTC value
            utc = false;
            if (vi >= utc_vcmd_size) {
                vi = 0;
                utc_value[10] = 0;
                utc_cmd_value = (time_t) atol((char *) utc_value);
                if (utc_cmd_value < DEF_TIME) {
                    utc_cmd_value = DEF_TIME;
                set_time(utc_cmd_value);
            break;
        case 'V': // begin power/utc value
            vi = 0;
            break;
        case 'X': // end power value
            utc = false;
            if (vi >= vcmd_size) {
                vi = 0;
                cmd_value = value[0]*1000 + value [1]*100 + value[2]*10 + value[3];
                if (cmd_value > GTI_MAX) {
                    cmd_value = GTI_MAX;
                if (cmd_value < 0) {
                    cmd_value = 0;
                INTERRUPT_GlobalInterruptLowDisable(); // 16-bit atomic update
                gti_power = cmd_value;
                INTERRUPT_GlobalInterruptLowEnable();
            break;
        case 'Z': // zero power
            utc = false;
            cmd_value = 0;
            break;
        case '+': // incr power
            utc = false;
            cmd_value = gti_power + GTI_INCR;
            break;
        case '-': // decr power
            utc = false;
            cmd_value = gti_power - GTI_INCR;
                cmd_value = 0;
            break;
        case 'I': // idle power
            utc = false;
            cmd_value = GTI_IDLE;
            break;
        case 'F': // normal operation
            utc = false;
            cmd_value = GTI_NORM;
            break;
        case 'M': // max unit rated power testing
            utc = false;
            break;
        case '#': // execute command symbol
            utc = false;
            break;
        default: // eat extra characters
            utc = false;
            while (Sready()) {
                mqtt_r = Sread();
            break;
// TMR5 one second time keeping in V.ticks.
void set_time(const time_t t)
    PIE8bits.TMR5IE = 0;
    V.ticks = t;
    PIE8bits.TMR5IE = 1;
* if t > 0, t is set to memory location of current_time variable
time_t time(time_t * t)
    static time_t current_time;
    current_time = V.ticks;
    if (t) {
        t = &current_time;
    return current_time;
The server power system is pushing excess power into the local house grid.
Q84 SPI DAQ data logging.
Scalar Index 0 is the SW/HW development system for finishing up the Linux driver to be multi-core for analog and to handle asynchronous Comedilib commands. https://www.comedi.org/doc/asyncprogram.html
Q84 remote DAQ, 4 PV voltages from two units (data calibration table Scalar Index 1 and 2).
Shed array PV voltage vs GTI input voltage in the house. DC feed-Line voltage drop.
Daily running control variables.
Finally finishing off the Q84 DAQ board firmware and the Linux SPI protocol driver for it.
One of the last things to do was to get the remote serial I/O sub-device completed. The simplest way was to use the Comedi MEMORY sub-device framework to memory map the TX, RX and RX ready data in four blocks of 16-bit memory space.
Then use my SPI packet protocol to update the memory blocks.
Linux SPI protocol kernel driver
C:
enum comedi_subdevice_type {
    COMEDI_SUBD_UNUSED,    /* subdevice is unused by driver */
    COMEDI_SUBD_AI,    /* analog input */
    COMEDI_SUBD_AO,    /* analog output */
    COMEDI_SUBD_DI,    /* digital input */
    COMEDI_SUBD_DO,    /* digital output */
    COMEDI_SUBD_DIO,    /* digital input/output */
    COMEDI_SUBD_COUNTER,    /* counter */
    COMEDI_SUBD_TIMER,    /* timer */
    COMEDI_SUBD_MEMORY,    /* memory, EEPROM, DPRAM */
    COMEDI_SUBD_CALIB,    /* calibration DACs and pots*/
    COMEDI_SUBD_PROC,    /* processor, DSP */
    COMEDI_SUBD_SERIAL,    /* serial IO */
    COMEDI_SUBD_PWM    /* pulse width modulation */
C:
* Serial TX/RX SPI Q84 transaction, 24-bit data
* This is memory mapped to the memory sub-device
static void serialWriteOPi(struct comedi_device *dev,
    uint32_t chan,
    uint32_t *value)
    uint32_t val_value;
    struct bmc_packet_type *packet = kzalloc(SPI_BUFF_SIZE_NOHUNK, GFP_KERNEL | GFP_NOWAIT | GFP_ATOMIC);
    if (!packet) {
        return;
    val_value = value[0];
    if (chan < 2) {
        // send TX packet
        /* use single transfer for all bytes of the complete SPI transaction */
        packet->bmc_byte_t[BMC_CMD] = CMD_CHAR_GO;
        packet->bmc_byte_t[BMC_D0] = (uint8_t) (val_value & 0xff); // serial data
        packet->bmc_byte_t[BMC_D1] = (uint8_t) chan; // serial channel
        packet->bmc_byte_t[BMC_D2] = (uint8_t) ((val_value >> 16)&0xff); // serial options
        packet->bmc_byte_t[BMC_D3] = BMC_D3;
        packet->bmc_byte_t[BMC_D4] = BMC_D4;
        packet->bmc_byte_t[BMC_EXT] = BMC_EXT;
        packet->bmc_byte_t[BMC_CKSUM] = CHECKBYTE;
        packet->bmc_byte_t[BMC_DUMMY] = CHECKBYTE;
        bmc_spi_exchange(dev, packet);
    // always check for received data
    packet->bmc_byte_t[BMC_CMD] = CMD_CHAR_GET;
    packet->bmc_byte_t[BMC_D0] = BMC_D0;
    packet->bmc_byte_t[BMC_D2] = BMC_D2;
    val_value = packet->bmc_byte_r[BMC_DUMMY]; // serial data
    val_value += (packet->bmc_byte_r[BMC_D2] << 8); // serial channel
    val_value += (packet->bmc_byte_r[BMC_D1] << 16); // serial data is fresh
    value[0] = val_value;
    kfree(packet);
These packets talk to the Q84 SPI slave and write/read/query the physical UART on the controller ISR for SPI interrupts
PIC18 firmware
C:
    // CHAR_GO_BYTES
    if (serial_buffer_ss.cmake_value) {
        if (serial_buffer_ss.raw_index == CHAR_GO_BYTES) {
             * uart1 only
            UART1_Write(serial_buffer_ss.data[BMC_D0]);
            data_in2 = 0;
            serial_buffer_ss.cmake_value = false;
            serial_buffer_ss.raw_index = BMC_CMD;
            spi_stat_ss.txdone_bit++; // number of completed packets
            spi_stat_ss.slave_tx_count++;
            data_in2 = 0;
        } else {
            data_in2 = 0;
    // CHAR_GET_BYTES
    if (serial_buffer_ss.cget_value) {
        if (serial_buffer_ss.raw_index == CHAR_GET_BYTES) {
             * uart1 only
            if (UART1_is_rx_ready()) {
                tmp_buf = UART1_Read();
            } else {
                tmp_buf = 0;
            SPI2TXB = tmp_buf;
            serial_buffer_ss.cget_value = false;
            data_in2 = 0;
        } else {
            if (serial_buffer_ss.raw_index == BMC_D0) {
                tmp_buf = 0x00; //
            } else {
                tmp_buf = UART1_is_rx_ready(); // new data is ready
            SPI2TXB = tmp_buf;
            data_in2 = 0;
    if (!V.do_fail && command == CMD_CHAR_GET) { // send the serial buffer
        spi_comm_ss.ADC_RUN = false;
        spi_comm_ss.PORT_DATA = false;
        spi_comm_ss.CHAR_DATA = true;
        spi_stat_ss.char_count++;
        serial_buffer_ss.raw_index = BMC_D0;
        serial_buffer_ss.cget_value = true;
        spi_comm_ss.REMOTE_LINK = true;
        TMR0_Reload();
    if (!V.do_fail && command == CMD_CHAR_GO) { // get data for the serial buffer
        channel = data_in2;
        serial_buffer_ss.cmake_value = true;
        TMR0_Reload();
The DAQ test program "bmc.c" exercises all sub-devices at close to max speed to check for possible hardware and software issues.
Test program fragments for testing the serial interface. It just send 0x57 to the physical port and reads the port for new data.
C:
    subdev_serial0 = comedi_find_subdevice_by_type(it, COMEDI_SUBD_MEMORY, subdev_serial0);
    if (subdev_serial0 < 0) {
        SERIAL_OPEN = false;
    if (SERIAL_OPEN) {
        fprintf(fout, "Subdev SER %i ", subdev_serial0);
        channels_serial0 = comedi_get_n_channels(it, subdev_serial0);
        fprintf(fout, "Digital Channels %i ", channels_serial0);
        maxdata_serial0 = comedi_get_maxdata(it, subdev_serial0, i);
        fprintf(fout, "Maxdata %i ", maxdata_serial0);
        ranges_serial0 = comedi_get_n_ranges(it, subdev_serial0, i);
        fprintf(fout, "Ranges %i \r\n", ranges_serial0);
    if (SERIAL_OPEN) {
        serial_buf = 0x57;
        comedi_data_write(it, subdev_serial0, 0, range_ao, AREF_GROUND, serial_buf);
        comedi_data_read(it, subdev_serial0, 0, range_ao, AREF_GROUND, &serial_buf);
        fprintf(fout, "%s Sending Comedi data to MQTT server, Topic %s DO 0x%.4x DI 0x%.6x\n", log_time(false), topic_p, bmc.dataout.dio_buf, datain);
        if (bmc.BOARD == bmcboard) {
            fprintf(fout, "ANA0 %lfV, ANA1 %fV, ANA2 %f, ANA4 %fV, ANA5 %fV, AND5 %fV : Scaler Index %d, Scaler ANA4 %f, Scaler ANA5 %f, Serial 0X%X\n",
                get_adc_volts(channel_ANA0), get_adc_volts(channel_ANA1), get_adc_volts(channel_ANA2),
                E.adc[channel_ANA4], E.adc[channel_ANA5], E.adc[channel_AND5], ha_daq_host.hindex, ha_daq_host.scaler4[ha_daq_host.hindex], ha_daq_host.scaler5[ha_daq_host.hindex],
                serial_buf);
        } else {
            fprintf(fout, "ANA0 %lfV, ANA1 %fV : Scaler Index %d, Scaler ANA4 %f, Scaler ANA5 %f\n",
                ha_daq_host.hindex, ha_daq_host.scaler4[ha_daq_host.hindex], ha_daq_host.scaler5[ha_daq_host.hindex]);
Clip to loop TX to RX connected and disconnected. It returns 16-bit data, so the UART status for fresh data is the high byte, 0x01xx
Here we have the module load kernel kprint status, the bmc test program logging as to becomes a background daemon process and the daq_bmc /sys/modules/daq_bmc/parameters of the configuration and various sub-device transaction counts.
C:
static int32_t daqbmc_conf = picsl12; // value 0
module_param(daqbmc_conf, int, S_IRUGO);
MODULE_PARM_DESC(daqbmc_conf, "hardware configuration: default 0=bmcboard standard, 1=bmcboard without DI or DO");
static int32_t di_conf = 1; // default true
module_param(di_conf, int, S_IRUGO);
MODULE_PARM_DESC(di_conf, "make digital input subdevice");
static int32_t do_conf = 1; // default true
module_param(do_conf, int, S_IRUGO);
MODULE_PARM_DESC(do_conf, "make digital output subdevice");
static uint32_t ai_count = 0;
module_param(ai_count, uint, S_IRUGO);
MODULE_PARM_DESC(ai_count, "total adc samples");
static uint32_t ao_count = 0;
module_param(ao_count, uint, S_IRUGO);
static uint32_t do_count = 0;
module_param(do_count, uint, S_IRUGO);
static uint32_t di_count = 0;
module_param(di_count, uint, S_IRUGO);
static uint32_t serial_count = 0;
module_param(serial_count, uint, S_IRUGO);
MODULE_PARM_DESC(ao_count, "total dac samples");
static uint32_t hunk_count = 0;
module_param(hunk_count, uint, S_IRUGO);
static int32_t hunk_len = HUNK_LEN;
module_param(hunk_len, int, S_IRUGO);
static int32_t bmc_autoload = 1;
module_param(bmc_autoload, int, S_IRUGO);
MODULE_PARM_DESC(bmc_autoload, "boot autoload: default 1=load module");
static int32_t bmc_type = 0;
module_param(bmc_type, int, S_IRUGO);
MODULE_PARM_DESC(bmc_type, "i/o board type: default 0=bmcboard");
static int32_t bmc_rev = 3;
module_param(bmc_rev, int, S_IRUGO);
MODULE_PARM_DESC(bmc_rev, "board revision: default 3=OPI Zero 3 4G");
static int32_t speed_test = 0;
module_param(speed_test, int, S_IRUGO);
MODULE_PARM_DESC(speed_test, "sample timing test: 1=enable");
static int32_t special_test = 0;
module_param(special_test, int, S_IRUGO);
MODULE_PARM_DESC(special_test, "special timing test: 1=enable");
static int32_t lsamp_size = 0;
module_param(lsamp_size, int, S_IRUGO);
MODULE_PARM_DESC(lsamp_size, "16 or 32 bit lsampl size: 0=16 bit");
static int32_t use_hunking = 0;
module_param(use_hunking, int, S_IRUGO);
https://github.com/nsaspook/mqtt_comedi/tree/cleanup
One of the cool things about these types of Linux drivers is the ability to run DAQ tasks on isolated and dedicated cores.
A C dds program has programmed the DAC channel for asynchronous operation. https://www.ni.com/en/shop/electron...rstanding-direct-digital-synthesis--dds-.html
This starts a kernel thread per the driver to handle the I/O from the program, to the Q84 internal DAC module
Here we see that core 2 process running: daqbmc_d/2
Various dds program output signals from the 8-bit DAC.
Not very fast but more than adequate for simple analog control signals.
TIC12400 (24-bit DI) and MC33996 (16-bit DO) full system loop (Q84 SPI2 I/O to the OPi routed via Q84 SPI1 to the DIO chips) driver testing.
I had to use something as the I/O standard. The ETT 10 pin boards are pretty cheap and have lasted many years testing various designs.
https://www.ett.co.th/product/13A02.html
https://www.ett.co.th/product/13A01.html
Waiting for the, hopefully, final JLC board spin with MODBUS and the FM80 charge controller on the Q84 DAQ PCB with the complete back-end server services and front-end Home Assistant HID interface on the Orange Pi Zero 3. This board and the Pi host will have all of the hardware I/O and software needed to control and monitor time-shifting hybrid solar energy systems with up to 48VDC battery banks.
Full system test-bed using the new DAQ board
EM540 energy monitor
FM80/60 charge controller
The needed sequence of commands and responses is handled on the 8-bit controller by a FSM, a set of callbacks and interrupt routines to TX and RX to format the returned data to the proper CSV format to send
to the Orange PI via the SPI link.
C:
    const uint16_t cmd_id[] = {0x100, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02};
    const uint16_t cmd_status[] = {0x100, 0x02, 0x01, 0xc8, 0x00, 0x00, 0x00, 0xcb};
    const uint16_t cmd_mx_status[] = {0x100, 0x04, 0x00, 0x01, 0x00, 0x00, 0x00, 0x05};
    uint16_t cmd_mx_log[] = {0x100, 0x16, 0x00, 0x00, 0x00, 0x01, 0x00, 0x17}; // get logs, start from day 1
    const uint16_t cmd_panelv[] = {0x100, 0x02, 0x01, 0xc6, 0x00, 0x00, 0x00, 0xc9};
    const uint16_t cmd_batteryv[] = {0x100, 0x02, 0x00, 0x08, 0x00, 0x00, 0x00, 0x0a};
    const uint16_t cmd_batterya[] = {0x100, 0x02, 0x01, 0xc7, 0x00, 0x00, 0x00, 0xca};
    const uint16_t cmd_watts[] = {0x100, 0x02, 0x01, 0x6a, 0x00, 0x00, 0x00, 0x6d};
    const uint16_t cmd_misc[] = {0x100, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02}; // example FM80 command ID request
    const uint16_t cmd_fwreva[] = {0x100, 0x02, 0x00, 0x02, 0x00, 0x00, 0x00, 0x04};
    const uint16_t cmd_fwrevb[] = {0x100, 0x02, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05};
    const uint16_t cmd_fwrevc[] = {0x100, 0x02, 0x00, 0x04, 0x00, 0x00, 0x00, 0x06};
    uint16_t cmd_time[] = {0x100, 0x03, 0x40, 0x04, 0x00, 0x00, 0x00, 0x47};
    uint16_t cmd_date[] = {0x100, 0x03, 0x40, 0x05, 0x00, 0x00, 0x00, 0x48}; // set to 5
    const uint16_t cmd_restart_ngit[] = {0x100, 0x03, 0x00, 0xd6, 0x00, 0x00, 0x00, 0xd9}; // using non-GTI mode
    const uint16_t cmd_restart_gti[] = {0x100, 0x03, 0x00, 0xd6, 0x00, 0x01, 0x00, 0xda}; // using GTI mode
    const uint16_t cmd_restart[] = {0x100, 0x03, 0x40, 0x02, 0x00, 0x01, 0x00, 0x46}; // restart command
static void send_mx_cmd(const uint16_t *);
static void rec_mx_cmd(void (* DataHandler)(void), const uint8_t);
 * callbacks to handle FM80 register data
void state_init_cb(void);
void state_status_cb(void);
void state_panelv_cb(void);
void state_batteryv_cb(void);
void state_batterya_cb(void);
void state_watts_cb(void);
void state_misc_cb(void);
void state_mx_status_cb(void);
void state_mx_log_cb(void);
static void state_fwrev_cb(void);
static void state_time_cb(void);
static void state_date_cb(void);
static void state_restart_cb(void);
 * serial I/O ISR, TMR6 500us I/O sample rate
 * polls the required UART registers for 9-bit send and receive into 16-bit arrays
void FM_io(void)
    IO_RF4_SetHigh();
    if (pace++ > BUFFER_SPACING) {
        if (dcount-- > 0) {
            if (tbuf[dstart] > 0xff) { // Check for bit-9
                U2P1L = (uint8_t) tbuf[dstart]; // send with bit-9 high, start of packet
            } else {
                UART2_Write((uint8_t) tbuf[dstart]); // send with bit-9 low
            dstart++;
        } else {
            dstart = 0;
            dcount = 0;
        pace = 0;
     * handle framing errors
    if (U2ERRIRbits.RXFOIF) {
        rbuf[0] = U2RXB; // read bad data to clear error
        U2ERRIRbits.RXFOIF = 0;
        rdstart = 0; // reset buffer to start
     * read serial data if polled interrupt flag is set
    if (PIR8bits.U2RXIF) {
        if (U2ERRIRbits.FERIF) {
            // do nothing, will clear auto
        if (rdstart > FM_BUFFER - 1) { // overload buffer index
        if (U2ERRIRbits.PERIF) {
            rdstart = 0; // restart receive buffer when we see a 9-th bit high
            rbuf[rdstart] = 0x0100; // start of packet, bit 9 set
        } else {
            rbuf[rdstart] = 0x00;
        rbuf[rdstart] += U2RXB;
        rdstart++;
    timer_ms_tick(0, 0); // software timers update
    IO_RF4_SetLow();
 * buffer received data
 * disabled using critical section interrupts here and it was too long 500us
 * and causing data errors
uint8_t FM_rx(uint16_t * data)
    uint8_t count;
    count = rdstart;
    if (count > 0) {
        memcpy(data, (const void *) rbuf, (size_t) (count << 1)); // copy 16-bit values
    rdstart = 0;
    return count;
 * transmit the cmd data
static void send_mx_cmd(const uint16_t * cmd)
    if (FM_tx_empty()) {
        if (BM.pacing++ > PACE) {
            FM_tx(cmd, CMD_LEN); // send 9-bit command data stream
            BM.pacing = 0;
 * process received data from the FM80 9n1 serial in abuf 16-bit buffer array with callbacks
static void rec_mx_cmd(void (* DataHandler)(void), const uint8_t rec_len)
    static uint16_t online_count = 0;
    if (FM_rx_ready()) {
        if (FM_rx_count() >= rec_len) {
            online_count = 0;
            if (rec_len == REC_LOG_LEN) {
                FM_rx(cbuf);
            } else {
                FM_rx(abuf);
            BM.FM80_io = false;
            DataHandler(); // execute callback to process data in abuf
        } else {
            if (online_count++ > ONLINE_TIMEOUT) {
                online_count = 0;
                BM.FM80_online = false;
                BM.FM80_io = false;
                cc_mode = STATUS_LAST;
                state = state_init;
    if ((BM.FM80_online == false) && online_count++ > ONLINE_TIMEOUT) {
        online_count = 0;
        BM.FM80_io = false;
        state = state_watts;
        mx_code = 0x0;
        DataHandler();
#ifdef MX_MATE
         * FM80 processing state machine
        switch (state) {
        case state_init:
            send_mx_cmd(cmd_id);
            rec_mx_cmd(state_init_cb, REC_LEN);
            break;
        case state_status:
            if (!BM.fm80_restart) {
                send_mx_cmd(cmd_status);
                rec_mx_cmd(state_status_cb, REC_LEN);
            } else {
                send_mx_cmd(cmd_restart);
                rec_mx_cmd(state_restart_cb, REC_LEN);
            break;
        case state_panel:
            send_mx_cmd(cmd_panelv);
            rec_mx_cmd(state_panelv_cb, REC_LEN);
            break;
        case state_batteryv:
            send_mx_cmd(cmd_batteryv);
            rec_mx_cmd(state_batteryv_cb, REC_LEN);
            break;
        case state_batterya:
            send_mx_cmd(cmd_batterya);
            rec_mx_cmd(state_batterya_cb, REC_LEN);
            break;
        case state_watts:
            send_mx_cmd(cmd_watts);
            rec_mx_cmd(state_watts_cb, REC_LEN);
            break;
        case state_mx_status: // wait for ten second flag in this state for logging
            send_mx_cmd(cmd_mx_status);
            rec_mx_cmd(state_mx_status_cb, REC_STATUS_LEN);
            break;
        case state_fwrev:
            switch (fw_state) {
            case 0:
                send_mx_cmd(cmd_fwreva);
                rec_mx_cmd(state_fwrev_cb, REC_LEN);
                break;
            case 1:
                send_mx_cmd(cmd_fwrevb);
                break;
            case 2:
                send_mx_cmd(cmd_fwrevc);
            default:
                fw_state = 0;
                break;
            break;
        case state_mx_log: // FM80 log data
            send_mx_cmd(cmd_mx_log);
            rec_mx_cmd(state_mx_log_cb, REC_LOG_LEN);
            break;
        case state_time: // FM80 send time data
            send_mx_cmd(cmd_time);
            rec_mx_cmd(state_time_cb, REC_LEN);
            break;
        case state_date: // FM80 send date data
            send_mx_cmd(cmd_date);
            rec_mx_cmd(state_date_cb, REC_LEN);
            break;
        case state_misc:
            send_mx_cmd(cmd_misc);
            rec_mx_cmd(state_misc_cb, REC_LEN);
            break;
        default:
            break;
        if (TimerDone(TMR_RESTART)) {
            StartTimer(TMR_RESTART, 30000);
            BM.fm80_restart = false;
#endif
 * testing online status while waiting for 10 second flag callback
    if (mx_code == FM80_ID) { // only set FM80 offline here
    } else {
        state = state_init;
        return;
    if (!BM.ten_sec_flag) {
        state = state_misc;
    } else {
        state = state_status;
    BM.log.volts_peak = (int16_t) cbuf[5];
    BM.log.day = (int16_t) cbuf[14];
    BM.log.kilowatt_hours = (int16_t) (((uint16_t) (cbuf[3] & 0xF0) >> 4) | (uint16_t) (cbuf[4] << 4));
    BM.log.kilowatts_peak = (int16_t) (((uint16_t) (cbuf[13] & 0xFC) >> 2) | (uint16_t) (cbuf[12] << 6));
    BM.log.bat_max = (int16_t) (((uint16_t) (cbuf[2] & 0xFC) >> 2) | (uint16_t) ((cbuf[3] & 0x0F) << 6));
    BM.log.bat_min = (int16_t) (((uint16_t) (cbuf[10] & 0xC0) >> 6) | (uint16_t) ((cbuf[11] << 2) | ((cbuf[12] & 0x03) << 10)));
    BM.log.amps_peak = (int16_t) (cbuf[1] | ((cbuf[2] & 0x03) << 8));
    BM.log.amp_hours = (int16_t) (cbuf[9] | ((cbuf[10] & 0x3F) << 8));
    BM.log.absorb_time = (int16_t) (cbuf[6] | ((cbuf[7] & 0x0F) << 8));
    BM.log.float_time = (int16_t) (((cbuf[7] & 0xF0) >> 4) | (cbuf[8] << 4));
    cmd_mx_log[5] = BM.log.select;
    cmd_mx_log[7] = 0x16 + BM.log.select; // update the checksum
    state = state_mx_status;
    volt_f((abuf[11] + (abuf[10] << 8))); // set battery voltage here in volt_whole and volt_frac
    vw = volt_whole;
    vf = volt_fract;
    volt_f((abuf[13] + (abuf[12] << 8))); // set panel voltage here in volt_whole and volt_frac
    pvw = volt_whole;
    pvf = volt_fract;
    if ((abuf[1] &0x0f) > 9) { // check for whole Amp
        abuf[2]++; // add extra Amp for fractional overflow.
        abuf[1] = (abuf[1]&0x0f) - 10;
    if (BM.FM80_online) { // don't update when offline
        bat_amp_whole = abuf[3];
        bat_amp_panel = abuf[2];
        bat_amp_frac = abuf[1];
#ifdef debug_data
    printf("%5d: %3x %3x %3x %3x %3x  SDATA: FM80 Data mode %3x %3x %3x %3x %3x %3x %3x %3x %3x\r\n",
        rx_count++, abuf[0], abuf[1], abuf[2], abuf[3], abuf[4], abuf[5], abuf[6], abuf[7], abuf[8], abuf[9], abuf[10], abuf[11], abuf[12], abuf[13]);
#endif
    if (BM.ten_sec_flag) {
        BM.ten_sec_flag = false;
        if (BM.FM80_online || BM.modbus_online) { // log for MX80 and EM540
            MM_ERROR_C;
             * log CSV values to the comm ports for data storage and processing
            BM.run_time = lp_filter(BM.run_time, F_run, false); // smooth run-time
            //            snprintf(buffer, 25, "%s", asctime(can_newtime)); // the log_buffer uses this string in LOG_VARS
            //            buffer[DTG_LEN] = 0; // remove newline
            //            snprintf(log_buffer, MAX_B_BUF, log_format, LOG_VARS);
            //            printf("%s", log_buffer); // log to USART
            switch (BM.alt_display) {
            case 3:
                break;
            case 2:
                break;
            case 1:
                break;
            case 0:
            default:
                break;
            //            snprintf(info_buffer, MAX_B_BUF, " Data OK\r\n");
    state = state_fwrev;
Integrated the daq_bmc data from the Q84 'master' interface card into the Home Assistant software running on the Orange Pi zero 3.
After the transfer via SPI to the OPi the input is validated to be good before posted the MQTT server as JSON formatted data.
I'm using a non-synchronized stop/start (only for testing) data stream to test error detection.
C:
        if (++slow_data > SLOW_DATA) {
            slow_data = 0;
            if ((daq_data_index > MAX_STRLEN) || (daq_bmc_data_text[BMC4.pos] == '^')) {
                comedi_data_write(it, subdev_serial0, 4, range_ao, AREF_GROUND, STX); // update daq_bmc data buffer
                daq_data_index = 0;
                strncpy(daq_bmc_data_buf, daq_bmc_data_text, SYSLOG_SIZ);
                BMC4.pos = 0;
            } else {
                comedi_data_read(it, subdev_serial0, 4, range_ao, AREF_GROUND, &daq_bmc_data[BMC4.pos]);
                daq_bmc_data_text[BMC4.pos] = (char) (daq_bmc_data[BMC4.pos] >> 8);
                serial_buf = daq_bmc_data_text[BMC4.pos];
                BMC4.pos++;
                daq_data_index++;
Data stream with proper sync code enabled and with the proper SPI spacing in the Linux driver between MASTER bytes sent to the Q84 to allow at least 50us between bytes, as to not overrun the 2 byte FIFO in the Q84.
https://manpages.debian.org/testing/linux-manual-4.8/schedule_hrtimeout_range.9.en.html
C:
static const uint32_t SPI_GAP = 20000; // time for the Q84 to process each received SPI byte
static int32_t bmc_spi_exchange(struct comedi_device *dev, struct bmc_packet_type * packet)
    struct comedi_subdevice *s = dev->read_subdev;
    struct spi_param_type *spi_data = s->private;
    struct spi_device *spi = spi_data->spi;
    int32_t ret = 0;
    ktime_t slower = SPI_GAP;
    if (spi == NULL) {
        ret = -ESHUTDOWN;
        return ret;
     * use nine spi transfers for the complete SPI transaction
     * we need the inter-byte processing time on the slave side
     * with only a two byte FIFO
    packet->one_t.speed_hz = spi->max_speed_hz;
     * send the cmd and 4-bit channel data
    packet->one_t.tx_buf = &packet->bmc_byte_t[BMC_CMD];
    packet->one_t.rx_buf = &packet->bmc_byte_r[BMC_CMD];
    packet->one_t.cs_change = false;
    packet->one_t.len = 1;
    spi_message_init_with_transfers(packet->m, &packet->one_t, 1); //one transfer per message
    spi_bus_lock(spi->master);
    ret = spi_sync_locked(spi, packet->m);
    spi_bus_unlock(spi->master);
    if (ret == 0) {
        ret = packet->m->actual_length;
Built another board to parallel the operation system for data and control comparisons on the Orange Pi.
Idle
Charging battery
Time to add some external current sensors to track in/out of the battery bank
200A Hall sensor PCB (200A or 100A Hall current sensors) to ADC input 0. Zero and scale at half of current sensor regulated 5vdc reference voltage to the adc0 channel with a 4.096vdc reference.
Test setup basic diagram
Enclosure for everything.
Basic power and reset wiring. Need to make a few cables for the I/O connector that will be on the back.
Isolated power for relay switching, reset button.
White or Black bezel?
Need to add a few controls on the top.
Now, the fun part, documentation of the interior and harness wiring, so I can remember what I did an hour from now.
Calibration of the two 65VDC ADC channels for the Solar Panel input and battery bank voltages on ANA5 and ANA5.
Calibration space (EEPROM and defaults in FLASH) for 4 Orange Pi host controllers and daq_bmc boards.
C:
     * scale adc result into calibrated units
     * for USB boards and BMC boards use MUI_id scales and offsets
#define HV_SCALE0               83.6f
#define HV_SCALE1               74.4f
#define HV_SCALE2               74.4f
#define HV_SCALE3               83.6f
#define HV_SCALE4               64.1890f
#define HV_SCALE5               64.1415f
#define HV_SCALE4_0             64.2600f
#define HV_SCALE5_0             64.2600f
#define HV_SCALE4_1             64.1890f
#define HV_SCALE5_1             64.1415f
#define HV_SCALE4_2             54.1890f
#define HV_SCALE5_2             54.1415f
#define HV_SCALE4_3             64.1890f
#define HV_SCALE5_3             64.1415f
#define HV_SCALE_RAW            4.096f
#define HV_SCALE_OFFSET         0.0f
#define A200_0_ZERO  2.5216f
#define A200_0_SCALAR  133.05f // BATTERY Amp scalar
#define BSENSOR0 0
#define OVER_SAMP       4
    struct ha_daq_calib_type {
        uint64_t bmc_id[4];
        double offset4[4];
        double scaler4[4];
        double offset5[4];
        double scaler5[4];
    struct ha_daq_hosts_type {
        const char hosts[4][NI_MAXHOST];
        const char clients[4][NI_MAXHOST];
        const char topics[4][NI_MAXHOST];
        const char listen[4][NI_MAXHOST];
        char hname[4][NI_MAXHOST];
        double scaler[4], scaler4[4], scaler5[4];
        uint8_t hindex, bindex;
        uint32_t pacer[4];
        struct ha_daq_calib_type calib;
double get_adc_volts(int chan)
    lsampl_t data[16];
    int retval;
    retval = comedi_data_read_n(it, subdev_ai, chan, range_ai, aref_ai, &data[0], 1);
    if (retval < 0) {
        comedi_perror("comedi_data_read in get_adc_volts");
        ADC_ERROR = true;
        return 0.0;
    bmc.adc_sample[chan] = data[0];
    ad_range->min = 0.0f;
        if (chan == channel_ANA4 || chan == channel_ANA5) {
            if (chan == channel_ANA4) {
                ad_range->max = ha_daq_host.calib.scaler4[ha_daq_host.bindex];
            } else {
                ad_range->max = ha_daq_host.calib.scaler5[ha_daq_host.bindex];
        } else {
            ad_range->max = HV_SCALE_RAW;
    } else {
        ad_range->max = ha_daq_host.scaler[ha_daq_host.hindex];
    return comedi_to_phys(data[0], ad_range, maxdata_ai);
Not too shabby and much better than the values from the FM80 charge controller panel voltage (the battery voltage can be calibrated on the FM80 but panel voltage read-back is fixed).
Have the 'boxed' version up and running as a power monitor for the PC in the media room. The Orange Pi Zero3 with Display and keyboard/mouse for local control and monitoring.
OPI in clear case with cooling fan.
Monitoring the remote and local DEV systems from my workshop.
Setup wireless power monitoring using Matter over thread. First we need a Thread Border Router to interface WiFi IPV6 to the thread radio IPV6 network.
https://openthread.io/codelabs/openthread-border-router#0
https://openthread.io/guides/thread-primer/node-roles-and-types
Two boards in one, connected via uart. Generic firmware build: https://docs.espressif.com/projects/esp-thread-br/en/latest/dev-guide/build_and_run.html
VS Code can be used with the ESP-IDF extension to customize the source.
https://github.com/espressif/vscode-esp-idf-extension/blob/master/README.md
Once the firmware(s) has been loaded on the boards, it's time to setup thread and matter on Home Assistant.
Adding the Eve Energy device via the HA phone app.
Ya’akov
Joined Jan 27, 2019
10,307
View attachment 357432View attachment 357433
That is a juicy dev board. I am having a hard time not clicking on "BUY NOW"—but I have too many dev boards in queue and other possibilities for using Thread and Matter so I have duct taped my hands to the desk. (Don't ask how I am typing this, that would be rude.)
Q84/OPi solar/energy monitor system: Right side, solar monitor sending data to Home Assistant with a full set on test panels and battery. Left side GTI inverter EM540 energy monitor on another set of panels.
Production panels vs BMC test panels voltages.
The load (off-grid inverter running one of two redundant PC power supplies) is my programming workstation at idle power.
