High precision 1mAmp current source
topic
Joined Aug 16, 2020
5
I am looking for a 1 mAmp DC current source circuit design with 0.02% precision to be used in a 5V power supply circuit board and a 3KOhms load.
Any suggestion/direction would be helpfull.
Thank you all.
38,740
Is the 3kΩ load grounded?
Is 0.02% also the accuracy you need? Why so precise?
What is the ambient temperature over which this accuracy is required?
AnalogKid
Joined Aug 1, 2013
12,254
And in addition to Wally's questions - do you have access to a 0.002% accurate resistor, voltage reference device, or both? Or an accurate meter to trim a very stable but off-value component?
ak
topic
Joined Aug 16, 2020
5
Thank you all for your replies and feed back.
The measurement will be used in reflection but will also be used in other applications from -30 ° C to room temperature.
These apps might not need that level of precision, but I want to find the most accurate current source that I can get with my resources.
I can have access to a 0.01% resistor and a 0.02% voltage reference.
The current will be measured using a current sense resistor coupled to an Inst. Amplifier connected to an ADC.
The load is grounded.
