It takes a while to get good at it.Hey...I tried it out on my breadboard (I still suck at soldering!)
There are differences.I'm using a IRF640...don't know if that's an equivalent MOSFET Wookie. I asked the guy in the electronics shop, he looked at what you sent and handed me these things. I think I have them plugged in right...downloaded a data sheet.
Short C1 to ground. One LED should be on, the other off.One LED is very dim but flashes...the other is very bright and does not appear to flash. In actuality, I think it may be strobing, but at a much higher rate...
Any ideas? Did I hook something up wrong?
What do you mean by "strobe"? Do you mean that D2 is on constantly?The LED hooked up to pins 8/12/5 (the right hand one on the schematic) has full power (700mA) but no strobe, while the other LED has strobe but is only pulling 10mA...and I switched the LEDs to see if that made a difference...but it's the same.
