MaxHeadRoom
- Joined Jul 18, 2013
- 30,806
What is wrong with the 555 based PWM controllers for around $5-$10 on ebay, or build one such as http://www.discovercircuits.com/DJ-Circuits/simplepwm2.htm ??Hello!
I am trying to run a somewhat beefy motor using a power adapter that outputs 12 volts, 8 amps DC. I'd like to be able to vary the speed of the motor using a potentiometer, preferably around 10k ohm or 100k ohm. I need a circuit design to power my motor with the potentiometer.
I also want the circuit to use no microcontrollers, digital potentiometers, or PWM of any sort. I'd like it to contain more basic circuit components, like transistors, resistors, and possibly capacitors. And the only power source should be the aforementioned power adapter, and no separate power sources like batteries to provide signals to the transistor(s).
If someone could specify a circuit design, I would appreciate it greatly!
Max.
