Hi, where is product detector?
Audioguru
Joined Dec 20, 2007
11,248
It is not a radio for voices or music, its output is a beep whenever there is a CW (carrier wave), like Morse code.
The beep tone is produced by the product detector difference between the radio carrier that is received and the BFO.
bertus
Joined Apr 5, 2008
23,031
On the HAM radio bands there are conversations between HAM's in SSB.
This can not be received with a normal AM receiver.
A product detector is able to detect the SSB signal.
If you want to to hear what happens on the short wave radio, you can listen online here:
http://websdr.ewi.utwente.nl:8901/
Bertus
28,593
Actually, that kind of mixer and a product detector are the same function, but used for different purposes, thus different names. Also called frequency converters by some folks. Sorry about getting into this thread late. Oh Well.
BR-549
Joined Sep 22, 2013
4,928
A "Beat Frequency Oscillator" is a special local oscillator.....purposely offset from carrier or IF. Hence the name beat. Meaning tone.
It can not be used to feed a product detector. If you feed a product detector with a BFO.....the product detector becomes a frequency converter. Mixing two different frequencies.
If you tune your BFO to the same carrier or IF......the BFO becomes a LO....local oscillator. Now the frequency converter reverts back into a product detector. Mixing two equal frequencies.
The math remains the same.......only the mixer and LO names are changed. The special names are a condition or circumstance.
The product detector can also detect frequency and phase shifts. FM detection.
28,593
In receivers used for CW (telegraph code) reception the BFO ALWAYS feeds the product detector and the result is an audio tone indication that the carrier is present. That is the only purpose of the BFO and product detector. The frequencies are not quite the same, usually about 700 Hz different. Thus the tone heard is that 700 Hz tone.
In a single sideband receiver the BFO is fed to the product detector to replace the supressed carrier, so as to uninvert the speech and make it understandable. For SSB reception the BFO frequency must be very close to the signal ferquency fed to the product detector.
For FM detection the BFO frequency should be the same as the other frequency, but 90 degrees out of phase, so that the difference is the audio frequency causing the change in signal frequency.
michael1978
Joined Jun 29, 2014
309
Hi, one more time me, i try to understand ssb, and i watch one video one YouTube, how they remove carrir frequnecy and lower side band, but
i dont understand, how the am signal looks in spectrum, til now i see only sine wave, how to say, how become signal in spectrum in sine wave?
when in spectrum they ary three sine, lower side carrier upper side, how come only one sinewave...…...
michael1978
Joined Jun 29, 2014
309
Hi, i understand single band how is working, but for those all am fm ssb dsb, in spectrum analyzer, like don look, like normal, how they look for example am sine wave, fm sinewave,
for example you see the picture how does look figure am a, in #55, but in figure am b, in #55 they look only three lines, this three lines i dont understand this three line verical
