Hi, where is product detector?
panic mode
Joined Oct 10, 2011
5,458
it is not shown (at least not in detail). check "diplexer" circuit, diode ring mixer.
everything before it is RF, everything after is AF (audio freq.)
michael1978
Joined Jun 29, 2014
309
Goodmorning, thnx for reply, i realy dont understand, because i want to make it, but after when i look, detector i cant see nowhere, i say what is this, i take from this site http://www.tuberadio.com/new.html only is show VCO and BFO more, and also he say , "The mixer/detector can be SBL-1 or TUF-1 types or homebrew" is this sbl-1 also detector?
BR-549
Joined Sep 22, 2013
4,928
You should google product detector and read several articles. A product detector is a special rf mixer. A mixer is different than a summer. It outputs the sum and difference of the input frequencies. A product detector is special because the inputs are the same frequencies.
What component has the same input frequencies?
michael1978
Joined Jun 29, 2014
309
michael1978
Joined Jun 29, 2014
309
Hi, i dont know man, i try to search in google " A product detector is a special rf mixer", i dont understand there 4 methods detectors, but i never hear about special rf mixer, i dont understand,
is possible to tell me where is, in that circuits special rf mixer thnx they say to use sbl-1 mixer(is this one)
michael1978
Joined Jun 29, 2014
309
BR-549
Joined Sep 22, 2013
4,928
You can build and use the radio long before you may understand it. Lots....lots of study will be needed before you understand it. That's why there are large text books to study.
If we explained it to you.......would you understand the words we use? You need to study definitions and concepts in an ordered manner. One particular concept is needed to be able to understand the next concept.
Unfortunately......we can not see voltage, or current flow. So we have to study.
michael1978
Joined Jun 29, 2014
309
I study man ,, can you please just tell me with a (little words, how is working), if you know, i search a lot in internet but without success, my plan was to make with foster seeley, detector because i understand, but after i found this circuits and i will like to make it, but like i said, i dont understand the detector....
BR-549
Joined Sep 22, 2013
4,928
Your post is confusing to me now. What are you trying to do?
What type of signal are you working with? Have you heard many FM signals on 40 meters?
Dodgydave
Joined Jun 22, 2012
11,395
Hi, Bertus, is this ring modulation diode, how is deomulated the circuit
A Ring Modulator is for a Ssb transmitter, where you only transmit a carrier when you speak, or send audio, this reduces the power requirements of the rf amplifier ,and reduces the bandwidth of the signal.
The output of the Ring Modulator has two products, the Sum and the Difference of the two frequencies being converted, these are the Upper and Lower sidebands, only one sideband is transmitted , so in theory two signals can occupy the same frequency and won't interfere with each other.
In the receiver the same circuit is used and an oscillator called a BFO is used to reproduce the original Audio signal.
You need to search and study SSB radio receiver circuits further.
michael1978
Joined Jun 29, 2014
309
Goodmorning, with fm signals, i dont know because i did not make it, like i told i was in plan somehing else to do, but this is all explained,only the product/detector not
michael1978
Joined Jun 29, 2014
309
Goodmorning i search yesterday i google, i know about bfo(beat frequency oscilator), but i will try also today to search ...thnx
michael1978
Joined Jun 29, 2014
309
Sorry....I can not understand what you are saying.
i say, i did not make the radio, this fm superhetero, but this have another detector,
and just now, i am reading one book, and in the book say, that mixer is product/detector, where is two input and one output, if output audio frequency, is this correct?
