Fotek SSR-25 AA (80-250VAC input side) output is 24-380.
Using a simple switch to take 120VAC into it to run a small 120VAC desktop fan in the garage. I know a relay isn't needed for this, but it was all I had lying around to test the relay on the workbench. The end result was to use a 120VAC motion sensor (garage light) to run a fog machine. Originally the machine to be used had a much lower voltage running through the push-button (not the typical halloween store 3-prong plugs). But, the fogger to be used has a basic 120V 3-prong plug and push button. But, I still wanted to test the relay to see how it worked.
The relay worked, cutting the fan off and on as planned, but there were some unexpected test results:
1. testing between 4 & 3 showed 120v--ok.
2. testing between 1& 2 when it's all running was .6 to .7 VAC. ?
3. testing between 1 & VCC or 2 & VCC was 120v.
4. When unplugged on the input side, with the fan's source still plugged in, the test across 1 & 2 went up to 120.
I just re-sketched the wiring diagram and will attach it below.
