help with reducing consumption for very small motor / low voltage buck
28,525
OK, so speed control is not required. This is indeed an unusual application. I am guessing that the solar cells are mounted in the picture frame somehow. One possible choice might be powering the motor directly from the solar cells.
There was a similar thread about a similar application here some years ago.
ludovic_pommier
Joined Jan 10, 2012
23
the motor used to be powered directly by the cells, but I know want the motor to keep running for a while after the cells stop outputting enough for the motor, hence the liion battery and the bq25570
28,525
The challenge is that the small number of solar cells only produce a small amount of power, and sharing that power between battery charging and motor spinning involves compromises. Making it more challenging is that any additional circuits are less than 100% efficient. Better motor efficiency would be the solution.
ludovic_pommier
Joined Jan 10, 2012
23
Agre
Agreed circuit efficiency is the key. The motor is already quite good (starts running at 144mv 11mA)
ludovic_pommier
Joined Jan 10, 2012
23
Ground Q1s emitter and take the voltage from the collector.
Below is the LTspice sim of an example circuit using a P-MOSFET is place of a diode across the motor to carry the current when the PWM signal is off:
Note that the voltage across the MOSFET is <10mV (yellow trace notation) when carrying the motor current (red trace) , much less than the 0.3V-0.4V a Schottky diode would have.
The MOSFET must be a logic-level type with a Vgs threshold of ≤1V maximum.
thanks for the detailed help. Just a question for selecting the P channel mosfet: I looked at the datasheet of the one in your schematics (si155dl) and it gives a 1.4v vgs with low rdson, am i missing something, not sure I really understand it? On mouser, I've found ZVP4424A , but it's more difficult to get and rdson is 9ohms. what would be the best choice? Can't seem to find low vgs low rdson?
