I recently purchased a 100k 2w potentiometer from Newark to replace a low quality 100k .5 watt potentiometer that appeared to be malfuntioning.
It is being used on a pulse width modulator to control a 24V trolling motor The output signal rises from 0-25% within the first 10degrees of the turn, then jumps sharply to 60%+ with the remaining increase spread over 90% of the knob travel. The ohm readings on the potentionmeter appear normal when not connected to the pwm. This was the same problem with the previous one. The PWM has power switch as well as a forward/off/reverse toggle. The "off position does not turn off the pwm power, just the output. The original unit worked properly during tests but then malfunctioned after it was turned up while the forward/off/reverse was in the off mode, but the pwm was still on.
In your opinion, could this have caused a malfunction in the PWM, or can I expect to achieve a less sensitive reaction using a different pot?
