Help with an Alkaline Battery Charger circuit
Al GR
Joined Mar 21, 2017
I wanted to build the alkaline battery charger in the diagram below and was hoping someone could confirm a few things about the circuit. I'm not sure who the original author is.
1. There is no connection for the Base of the transistor in the diagram ? What should it be connected to ? Directly to ground ?
2. Would it make sense that the variable resistor is 47 Ohms or should it be 47k Ohms
3. The circuits calls for a 9.5v AC power supply. Could I power this with 9.5V DC knowing that the second 1.5v charging circuit ( lower in the diagram ) would not work.
Thank you
38,947
You do realize the alkaline batteries are not meant to be charged, and if you try, will likely only provide a slight recharge, if any?
AlbertHall
Joined Jun 4, 2014
12,663
And the batteries may object to being charged by leaking electrolyte.
The base of the transistor is supposed to be disconnected. Used this way they don't conduct until the voltage reaches a threshold value and they conduct and dump the charge stored in the capacitor into the battery as a pulse. Read here.
I don't know whether this would work well with a DC supply. Someone may be along shortly to do a simulation.
tcmtech
Joined Nov 4, 2013
2,867
Unless its a purposely designed rechargeable alkaline battery you wont get anything for your efforts but a ruptured battery which typically destroys the charger or the device it's in via chemical reactions with whatever metal is near it.
ian field
Joined Oct 27, 2012
6,536
You can get acceptable results with pulse charging methods as long as they're not discharged too far - there were rechargeable alkalines released onto the market, but probably weren't much good, I haven't seen any on the shelves for a while.
There's a very old plan for charging zinc-carbon cells; as simple as a transformer with half wave rectifier - the diode is shunted by a resistor so a small back flow occurs between the forward conduction half cycles.
tcmtech
Joined Nov 4, 2013
2,867
I had a bunch of those for a while. The first generation of them were fair but life expectancy was way short of advertised.
Next generation that came out turned out to be rather fair. I found they lasted a decent run time and took way more charges than the first ones I had.
Last ones were the new eco friendly and were crappier than the first generation os since then I gave up on the idea and went with the NiMH ones. Still have them and they still work well when needed even after two years and more!
ian field
Joined Oct 27, 2012
6,536
High frequency pulse charging works brilliantly for reviving old Ni-Cd cells - but doesn't do Ni-Mh any good.
I was experimenting with a modified AT PSU to try to improve on the pulse method for alkaline - the results on alkaline were unimpressive, but astounding with Ni-Cd.
Al GR
Joined Mar 21, 2017
Thanks for all the replies and info. I didn't know transistors could be used that way as a pulse generator. I kinda figured the results wouldn't be fantastic recharging alkalines and am aware of the possibilities of leakage even if "properly" charged but I'm going to give the circuit a try just for fun. I'll post back with the results. Thanks.
sema77
Joined Apr 7, 2024
For the information of all who responded to this thread and did not know, a new chemistry has been created and rechargeable alkaline batteries are now available in sizes AA, AAA, C, D AND 9v.
38,947
Those were available a number of years ago, and suffer from only being recharged a few tens of times before losing much of their capacity as compared to several hundred recharges for NiMH types..
Also their Ah capacitor is only about 70% of a NiMH's (although their charged voltage is about 1.5V versus 1.2V which may be important for some applications, such as using them in series to make a 9V or 12V battery).
