Help wiring a 2 wire solenoid valve with a solid-state relay
Dakk33
Joined Jun 19, 2019
To start off I'm fairly new with electronics so please excuse any ignorance.
My end goal is to be able to actuate a solenoid valve by sending a 5V signal to the relay.
Relay: https://www.mouser.com/datasheet/2/240/CPC1706-1548577.pdf
Solenoid: https://www.parker.com/Literature/P...re Solenoid Valves/Series 9 Gas datasheet.pdf
My power source is a 6 cell, 22.2V 4500mAh Lipo battery connected through a 24V step-up DC booster (https://www.pololu.com/product/2582)
I'm not very familiar with the solenoid or relay. I do know that I need a resistor on the negative end of the signal for the relay, I have a 1k resistor there and am sending a 5V signal with a DC power supply (later this will be controlled with a microcontroller of some sort). I've seen that it's common to put a diode in parallel with the solenoid, however I'm not sure why this is or what kind of diode I will need. Also, I feel that I need a resistor of some sort in series with the solenoid but am not sure.
Any help (or circuit diagram) would be very much appreciated.
Thank you
MaxHeadRoom
Joined Jul 18, 2013
30,818
You may not need the DC boost, as the relay should operate a some point below its rated voltage.
And with a 500ma consumption, should not be excessive load for a LiPo battery.
Using a resistor for test purposes, it does not matter what lead you wire it in on the relay input.
Those are Hi speed dispensing solenoids, so keep in mind that any diode suppression is going to slow the output switch off some. That is if needing the Hi speed feature.
Max.
Dakk33
Joined Jun 19, 2019
Max.
I'm not sure we will need an incredibly high speed response (not upwards of the rated 6ms). Would you recommend a flyback diode? If so, what type should I be looking for?
