Help understanding - an old bitcoin ASIC miner.
Papabravo
Joined Feb 24, 2006
22,111
Your externally posted material is inaccessible. I don't think your quest has much chance of success since the firmware is probably locked down so you won't be able to copy it in case you brick the device while fooling around with trying to program it.
ca2285538
Joined Dec 17, 2023
16
i dont care if the device makes it out alive as long as i learn new things,
KeithWalker
Joined Jul 10, 2017
3,618
Your URL is to a zip file which I will certainly not install on my computer. Give us a URL to the hardware you are discussing so we can see what it is. Then we may be able to answer your questions.
ca2285538
Joined Dec 17, 2023
16
I do not have any link to the hardware i only have the files, i will provide the files as pdf is someone wants to tell me how to make them pdf files
35,171
"Help understanding" what?
You need a better title than that. It helps readers if the thread title provides some information on the contents of the thread.
What is this obscure "device"?
Papabravo
Joined Feb 24, 2006
22,111
He said it was an ASIC used as a bitcoin miner. ASICS are normally programmed from an 8-pin serial flash device.
Papabravo
Joined Feb 24, 2006
22,111
That is probably only possible with the original software that created the schematic files. The ".c" should not require conversion to ".pdf" format. Do you have a compiler for the ".c" files?
WBahn
Joined Mar 31, 2012
33,186
ASICs usually don't require programming at all and, if they do, it will be however the designer of the ASIC chose to program them. If it's an FPGA (which is NOT an ASIC), then configuration via a serial flash device is a common choice.
Papabravo
Joined Feb 24, 2006
22,111
You're right, I did conflate the two technologies. The TS called it an ASIC, perhaps making the same mistake that I did. We really don't know what he is working with. I've never made a bitcoin miner and I have a hard time believing that anyone would consider making a masked programmed part for that purpose. The FPGA path would have entailed far less risk and capital.
Janis59
Joined Aug 21, 2017
1,894
Original link to asker`s (ca2285538) file leads to suspicious server what multiple times redirects (virus beeper is blinking red, red, red) while ends on file download what loads, loads, loads and in 5 minutes loads nor even the one bite. I am more than sure its a virus and only thanks my system is Linux it cannot be harmed so easy.
ca2285538
Joined Dec 17, 2023
16
hum virus what you talking about the link is to google drive
also the first link i posted was a link that is for freelance programmers and other things the name is freelancer.com
ca2285538
Joined Dec 17, 2023
16
the program used to control, run the device, process the results called it ASIC it could be FPGA
