DickCappels
- Joined Aug 21, 2008
- 10,662
If the part you bought from Malpin is not marked "X2", you should not use it because it could pose a fire or other safety hazard.
Would either of these be good? I can swing by Cricklewood on my way home.I'm pretty sure you are going to need 1-2W resistor.
Hello All,Check the voltage and see if it drops when motor stalls.
| Thread starter | Similar threads | Forum | Replies | Date |
| T | Help required Stai | Power Electronics | 1 | |
Need help in this question | Homework Help | 1 | |
| M | Help Required for .asy file generation. | PCB Layout , EDA & Simulations | 6 | |
| A | DIY PCB, etching help required. | PCB Layout , EDA & Simulations | 12 | |
| S | Help required to identify circuit board | Datasheets, Manuals & Parts Identification | 34 |
