Hi all, I need to build a circuit that will switch a low voltage signal when a high voltage (240VAC RMS) is detected. Basically I have an existing circuit as below:
AC LOAD
where the '/' is a switch on the active line. (sorry for the crappy drawing . Once that switch is closed I need to close a circuit between an input and a 5V rail but I am unsure how to accomplish this. The best way I can think of doing it is to wire in a step down transformer/rectifier/filter to drive a relay but this seems overly complicated for the outcome I need to achieve. The other way is to use the 240V switch to connect the 5V rail to the input but I will need someway to isolate the high voltage portion of the circuit.
Can anyone suggest the best way to do this?
Cheers
Mick
AC LOAD
Cheers
Mick
