That is not a question. Even if it was, we need more background info - what are you trying to do? What do you have as a starting point (tools, strategy, input signal, desired result, ...)
- RF amplifier with gain 20dB and B.W 10kHz circuit pleeeease
How ever did you glean all of that from the OP?!A 14 GHz Ku band radar signal amplifier circuit is difficult to design. What power supplies do you have to run the circuit?
A particular set of skills...How ever did you glean all of that from the OP?!
Best regards
HP
I've met someone with those skills before...A particular set of skills...
An analog of digital.An analog of what?
Did your professor build any background as to the homework assignment? Or did he just throw you into the viper pit? And, given your original question, how would YOU answer it?Thank you guys for your responses, after all that was a project required by my professor
so I came here and asked you
by Don Wilcher
