Help identifying this smd fuse
artvandalai
Joined May 30, 2024
27
I need help identifying this smd fuse on a Philips sonicare pcb so I can order the correct part from digikey. I believe i blew the fuse attempting to fix another part of the board as it shows no continuity on the multimeter. I thought i bought the correct fuse but it was much bigger than the one I needed. https://ibb.co/QFS4xrb
https://ibb.co/V2vFdGq
panic mode
Joined Oct 10, 2011
5,250
so the one you got has form factor 1206, what you need seem to be 0603 or 0805. cannot tell for sure as the image is cropped so that there is nothing near the fuse to help estimate size. you can measure it...
1206 means size is 0.120" x "0.060" (read first two digits after decimal point and look at dimensions in first image).
artvandalai
Joined May 30, 2024
27
I currently dont have a micrometer caliper to measure correctly. The fuse is next to a 1206 fuse 3.18mm x 1.52mm and a PTS815 SJG 250 SMTR LFS tactile switch 4.20mm x 3.20mm
