Help Identifying an Oscialltor/Crystal
themtbiker
Joined Dec 5, 2022
Folks,
Can anyone identify this 44.236 MHz oscillator? Vendor or PN would be very helpful. I assumed ANKAE was a vendor, but I could not find anything via a Google search.
Thank You in advance.
ronsimpson
Joined Oct 7, 2019
4,814
I cannot find ANKAE. Probably 44.236mhz. I can find 44.236mhz. It is an off the shelf number. Do you know what supply voltage it runs at?
themtbiker
Joined Dec 5, 2022
I don't know the voltage, but I did learn that the frequency of the board is supposed to be 44.2368 MHz. The part is buried in unit, as such making measurements will be a challenge.
ronsimpson
Joined Oct 7, 2019
4,814
44.2368mhz is more common.
digikey They have 50 different part numbers for 44.2368mhz.
Supply voltage, type of output (TTL/CMOS/ECL/ETC), enable pin, temp stable, .......
