It is going to be used with the autopilot from my boat. I will post my progress as time goes on! Currently I have gathered up a step-servo motor, fluxgate and processor. I'm guessing around 1989 for the date. Thank You All for your input here! Robairplane? I presume it is and agree on the answers. I suspect that autopilot is >10 years old, probably >30 years old. Is this repair being made by a certified avionics repair station?
John
Thanks so much!hi,
Two data-sheets for these devices.
E
Now I can sleep at night.It is going to be used with the autopilot from my boat. I will post my progress as time goes on! Currently I have gathered up a step-servo motor, fluxgate and processor. I'm guessing around 1989 for the date. Thank You All for your input here! Rob![]()
Interestingly the PID method of servo control originated in designing auto pilot for a boat, this was done by studying the Helmsman and details on how the corrections were made manually to formulate the PID loop we know.It is going to be used with the autopilot from my boat. I will post my progress as time goes on! Currently I have gathered up a step-servo motor,
Thanks for the info Max! This is true! Being that I was in the control industry myself for 20 some odd years, I perfectly understand your thinking! Corrective actions are easy to manage, however, the reactions of PID loop must be adjusted during the timing oddly to a constant changing set point. ie. the vessels GPS or navigational system. Not trying to reinvent the wheel but to better understand Motion control with Longitude and Latitude having an effect on reaction timing of a PID loop. Thanks again for you share of knowledge. Regards, RobInterestingly the PID method of servo control originated in designing auto pilot for a boat, this was done by studying the Helmsman and details on how the corrections were made manually to formulate the PID loop we know.
Yes John Very Nice! Will take a look-see. Thanks again for your support and help!Now I can sleep at night.
Sounds like a neat application. Here is an application note from Microchip you might find interesting: http://ww1.microchip.com/downloads/en/AppNotes/00996a.pdf
John
Thanks for the help here!! I looked for the IC CA358(E) cant seem to find it yet??You don't need to know the manufacturer:
http://pdf.datasheetcatalog.com/datasheets/90/62591_DS.pdf
http://pdf.datasheetcatalog.com/datasheet2/5/0q31rz2l22saewqwyx0shif48k3y.pdf
these are standard components
It's in the first linkThanks for the help here!! I looked for the IC CA358(E) cant seem to find it yet??
Regards, Rob
Got it.. Thanks soo much! RobIt's in the first link
