Help identify a component?
lawrence101
Joined Oct 23, 2017
56
you are wrong... that is just date code. actual mark is UG and it is a LittleFuse part (see the logo).
you shrunk the view waaay too much and left absolutely no clue on dimensions... looks like bidirectional TVS in SMA package, and ... reading open circuit is normal for likely candidate - SMAJ350CA
https://www.littelfuse.com/assetdoc...ssetguid=13c2a823-03b8-4d1f-9ddc-9b44670aed9d
https://smd.yooneed.one/
Thanks PM for responding, i zoomed the view for clarity on the part # ( UG ) , It's connected across pins TM2 and the Gate pin of a Q6040K7 Triac . Its from a digital wall thermostat that wasn't working and had a blank display , i replaced it with a new one but was interested in repairing it as its barely a year old ( ~$60 part ). I've since made some rough drawings of the circuit layout based on looking at the board traces.
Thanks for clarity on the part number and function.
I'll include some extra shots of the board in question:
Based on the labeling on the PCB it's a high voltage controller. Probably for electric baseboard heating, 240 VAC. If I'm wrong - please let us know about the whole system; gas, electric, hydronic, etc.
That marking doesn't ring a bell, unfortunately. It could be a diode or some kind of protection component, but it's hard to tell just from the code. Have you tried checking where it connects on the board? That might give a better clue about what it's supposed to do. Also, if you're measuring it while it's still soldered in place, I'd double-check the reading with one side disconnected. Would be a shame to replace it and find out the problem was somewhere else
ericgibbs
Joined Jan 29, 2010
21,654
Web search clip:
The markings UG and 5C2BU typically identify a Littelfuse bidirectional TVS (Transient Voltage Suppression) diode, most commonly the SMAJ350CA. [1, 2]
How to decode the markings
    • UG (Device Code). This two-letter code identifies the actual part number. For Littelfuse components in a standard 2-pin SMA (DO-214AC) surface-mount package, UG maps to the SMAJ350CA (a 400W, 350V bidirectional TVS diode). [1, 2, 3]
E
