Hey guys,
I'm trying to build a boost converter to charge up the capacitors for a school project, but I don't seem to have very much success. I'm trying to boost 12v up to 750V, which requires a duty of 98.5% if my calculations are right. With the use of some online calculators (namely: http://www.daycounter.com/Calculators/Switching-Converter-Calculator.phtml and) I got an inductor value of 42mH, and have a 100mH inductor plugged into my boost converter to test. The capacitors I have plugged into the output are two 100uF caps rated at 450V in series. (The final capacitors I need to charge are 4050uF rated at 800V) But when I measure the output, I get only 0.655V.
I can't seem to figure out why I am not getting any useful values, can any of you help?
Thanks
Thanks
