MisterBill2
- Joined Jan 23, 2018
- 28,325
That implies that it is only one input for the control. That will be simple to verify, and I hope that I am wrong with that evaluation. It can still be either way, possibly. The resistance check will verify if there are two inputs or only one input and different resistances for each button.I just tried adjusting temperature with both sides simultaneously but only one goes up. Doesn't recognise both of them at the same. The side that goes up is the button that gets pressed the first
