heatsink for TO-3 from ebay dimensions
DickCappels
Joined Aug 21, 2008
10,662
Here is the hole pattern from the On Semiconductor datasheet for the 2N3055. You can use it to place your device mounting holes. The rest of the design is up to you -metal type (use blackened aluminum if you can get it), dimensions, fins or not, etc. all your choice.
You may also want to review existing designs on distributor websites or in heatsink catalogs.
38,646
Such a heatsink could also be used for other heat-sink mountable power packages, such as the TO-220, by using one of the holes for mounting, and ignoring the other holes.
Note that you should always use thermal grease when mounting the package to a heat-sink.
