Contact surface of a heatsink for a LED COB
jobee
Joined Mar 10, 2023
21
Hey folfs !
I am looking to cool a COB LED. This is a "bicolor" COB (kelvins may vary). See attached file. The COB is composed of a 200w warm white and a 200w cold white. I would like to use these 2 colors up to 150 w each. A total of 300w. I beleived the LED is for a total of 200w, but the seller said me it 200w for each color.
My problem is that the LED is large (diameter 58mm), too large for a CPU heatsink (whose cooling surface may be a square of 40mmx40mm). I wonder if by installing the LED on a heatsink of this type, the edges of the LED which will not be in contact with the heatsink will overheat. If so, I wonder what trick to find. Can I attach a larger copper plate to the heatsink to attach the LED or will this be counterproductive?
panic mode
Joined Oct 10, 2011
5,281
image shows that 58mm is just the lens diameter, product diameter is 68mm.
i would use copper plate and braze copper coil to it, then use liquid cooling.
jobee
Joined Mar 10, 2023
21
Wow, thanks a lot for this answer!
Actually heatsink designed for high power LEDs like you linked me are available on website with a huge minimum order. I can't find for 1 or 2 units on Aliexpress for exemple. I think I will do your idea with copper coil. Thanks a lot!
