Also, is there a site that you'd recommend for buying an Uno? Preferably i want avoid the official site as i don't have a lot of money or time, but obviously i want it to function correctly.hi e,
I also use this method of disconnecting rx and tx pins before uploading and it works for me. As for the AT command mode, i've tried many different methods including changing the pins and changing the baud rates etc with no success. I feel like the most likely solution is to buy an Uno and set the modules like you have done. Is it possible to set the modules with the Uno but then plug them back into the circuit with the nano, will it still work the same as slave and master?
Thanks
Thanks
