I’m using a A1344 Hall effect switch to replace a reed switch in a homemade anemometer. The pulses are fed to the input of a LM2917 frequency to voltage converter. The sensor output is positive by default, but I need an output which only becomes positive when the magnet passes by.
is there another Hall sensor which does this?
