Grounding
iamtheone33339
Joined Feb 13, 2024
18
I am trying to build an audio project that requires +-25 to 50vdc I have put the secondary wires from a 50vac transformer into a rectifier full bridge I think g3sba20. Where do I get a ground to complete the circuit? From the chassis of my amp, or?
dl324
Joined Mar 30, 2015
18,376
Your requirements aren't clear.
  1. Do you require -25V and 25V that's adjustable to 50V (but not -50V)?
  2. What current do you require?
  3. What is the current capability of the transformer?
  4. Is the secondary center tapped?
The transformer you want to use doesn't seem like a good choice unless you use switching regulators, but regulator noise could be problematic for an audio project. You could put linear regulators after switching regulators, but it'd be better to pick a transformer with a more appropriate secondary voltage.
Reloadron
Joined Jan 15, 2015
7,892
Most audio amplifier power supplies I have seen are unregulated and if you want a dual supply as in +25 volts and -25 volts you start with a center tapped transformer and the center tap becomes your ground. I suggest you Google "dual power supply schematics" as a starter. Your narrative is a little weak but I gather you are looking to power an audio amplifier.
I'm trying to make a dual dc power supply with what I got
Then I hope you have a center tapped transformer.
Ron
ThePanMan
Joined Mar 13, 2020
932
It's likely your secondary 50VAC needs a center tap. Hence, the comment on post #
you need a dual 25VDC power supply? Like 25VDC - 0 - 25VDC?
And for audio you're going to need to filter that rectified DC. your 50V will become over 70VDC Filtered. Or 35VDC - 0 - 35VDC.
Most audio amplifier power supplies • • • are unregulated and if you want a dual supply as in +25 volts and -25 volts you start with a center tapped transformer and the center tap becomes your ground. I suggest you Google "dual power supply schematics" as a starter.
Ron
Quote partially edited
The reason for quoting Ron is because he's right. And so is DJ. Whether you get a dual power supply or build one yourself, you're going to need a good plan and schematic. It's the road map to building anything electronic. Unless you're building a flashlight. In that case all you need is a battery, some wire and a light bulb. But for an amp you're going to need a lot more than an idea.
