I am one who has consistently misused it, but am going to do better in the future. As I use 1c, should it be labeled Com or something else or left unlabeled?1a Correct but often misused as an all encompasing power common as well as Earth Ground.
See section 1 & 111 for the comments on incorrect usage.
Ground Practices
1c would have a A or D label, often inside the triangle.Analog ground or digital ground?
You are correct on both counts. That's one of the reasons I posted the question.I found it odd that the Art Of Electronics, often used by those as a learning tool, (mis)uses the symbol all the way through the book.
Also I do not recall ever seeing a list of symbols and their usage in schematic drawings etc in the book.
Learn something new every day.The figure below is from an article in the June 2016 issue of Nuts and Volts. Is there any disagreement with it from the experts here?
Thanks.
Thanks.
