- Joined Jul 18, 2013
- 30,859
The reason I prefer to use the term 'Common' instead of ground, is that in N.A. the term ground is used for Circuit common point And also Earth ground, so If I am making reference regarding the power common reference point, it is less likely to be ambiguous as to whether the point in question is at earth or NOT!as it was stated by Max that ground and common were the same thing).
Unfortunately the Earth symbol is often used whether the reference point is earth grounded or not.
