Gone fracking!
loosewire
Joined Apr 25, 2008
1,686
Google did not spend much time mapping ,someone post a good map of mountrail
county,North Dakota or Williston. Only ads for paper map books for travel. The roads
are built 15,000 trucks ,they see 180,000 trips for short period of time.....show me the
the maps.
tcmtech
Joined Nov 4, 2013
2,867
Use google earth if you want a good view of whats out there. The last update they did is in a high enough resolution you can easily pick out where the vehicles are on the roads. ;)
Brownout
Joined Jan 10, 2012
2,390
@ Brownout ,you are good at cost of living ,how does the distant ,housing, cost of living
compare to the good money.
Haha, Loosie, The last time I worked out of town, the money was very good and covered all my expenses. I tried to keep my expenses low by living in a little trailer I can pull with my vehicle. But I haven't worked in about 6 months now, and so I'm forced to live on savings, which are disappearing quickly.
To answer your question, living away doesn't mean you're spending a lot more money. Food, utilities, gas and such doesn't necessarily change, you'd be spending money on those things anyway. The extra money you spend come from housing, but you can partially cover that by claiming per diem. There is also some things you must pay for back home that you would otherwise do yourself, like yard maintenance. Just do the math, and make sure you ask for enough to cover your costs.
loosewire
Joined Apr 25, 2008
1,686
It will be interesting to follow this thread ,they keep saying big money...far away. Then
they say there are many things that could go wrong. It is against the law in many
states to disclose what fracking juice they use. They are fracking in the Everglades ,
they just received more permits to drill. I think we have a pipeline to the port ,we don't
see the trucks. The only trucks ,take gas to stations that come from ships...go figure
where that gas is coming from.
tcmtech
Joined Nov 4, 2013
2,867
I will give you more info when I go back to work. Right now I am on my week off. I work 14 - 15 days on and 6 - 7 off. :D
tcmtech
Joined Nov 4, 2013
2,867
What I know so far.
Proppant = Sand of which is used to 'prop open' the cracks that happen as the formation material cracks open.
Around here most often normal sand is used that has been screened to a specific size range. After that polymerized sand is used.
The polymerized sands and or ceramic beads are basically inert being all they are is just inert sand or ceramic materials that have been coated in a plastic polymer that once put down the well will bond to itself so that it does not get washed back out as oil is drawn out. BTW it comes in a rainbow of colors depending on what temperature and pressure it is supposed to bond together at or with what reagent is to trigger it to bond.
Typically a single well will use many hundreds of thousands to a few million pounds of the stuff. ;)
tcmtech
Joined Nov 4, 2013
2,867
Acid = Industrial hydrochloric acid.
When a new zone is being opened up in a well initially a few tens of bbls (500 - 1500 gallons) of hydrochloric acid will be pushed down the well to help dissolve the formation material. Depending on the number of zones and size of the well this may be done 10 - 40 times during the fracking operation.
For the most part the hydrochloric acid reacting with the formation material turns into Calcium, Sodium and Potassium salts and hydrogen gas which comes back up the well with the production water and naturally occurring methane. ;)
tcmtech
Joined Nov 4, 2013
2,867
We don't have down time. :p
The company I work for is very proactive on doing proper maintenance to our equipment so that things don't have major breakdowns when on site. :cool:
Unlike past companies I worked for the equipment here is not old beat up worn out junk that should have been retired 20+ years ago. The oldest things we have are less than two years old and have fewer than 2000 running hours on them!
Now for me as an E tech as long as everything works I honestly sit around doing a lot of nothing for most of my 14 hours shift. Mostly I just walk around the site picking up garbage and talking to the guys about how their machines are running along with learning how they do their jobs. :cool:
I would like to do more but I have actually been told that I am not supposed to do any heavy work or hard labor work. Light assisting and watching everyone else work is about all I am allowed to do. :(
Granted in a way thats good being my lower back has been giving me problems for the last few months and it does not take much to aggravate it.
tcmtech
Joined Nov 4, 2013
2,867
To be honest I am very grateful for this job despite the fact I really did not want to get a job this summer. :)
I have easy work and excellent pay by my expectations and I am gone all the time now so my wife finally got to learn some appreciation for everything that I did and do around here. ;)
I really like the wife learning some appreciation the hard way part. :D
#12
Joined Nov 30, 2010
18,224
Must be a different kind of woman up there in "farther North America". The ones I know don't learn, they just add, "gone all summer" to the list of resentments.
I know I'm supposed to write :D after that, but I feel honest this morning.
tcmtech
Joined Nov 4, 2013
2,867
I never said she is actually learning from it. She is dealing with it with the option to learn being there.
It was her idea that I get a job opposed to working on the new house so now she has to deal with the repercussions of her decision which now means I have a job and the new house project is going to just sit there. :D
BTW my wife is from Turkey and the concept of think first and speak later is beyond her capacity to grasp. :rolleyes:
#12
Joined Nov 30, 2010
18,224
I know several like that. Only 2 days ago, I asked one of them, "Have you ever consider that you might have a thought that doesn't come out of your mouth?" I further explained that when she says every thought she has, we can't tell which ones are important, and we eventually get tired of listening in case anything important arrives.
She carefully explained that she has the right to talk incessantly and all men are required to listen constantly.
Believe it or not, that was one of the smarter ones. I wouldn't even bother explaining this to my niece-in-law.
ps, thanks for the LOL.
WBahn
Joined Mar 31, 2012
33,326
Boy, listening to you guys just underscores how fortunate I was in the lady I managed to find! I've got a keeper in just about every respect.
tcmtech
Joined Nov 4, 2013
2,867
I go through that constantly. I can't count how many times I have asked her if she is talking to me or just talking because she has words to use up.
Apparently most of the time she is not even aware she is talking out loud. :(
Daughter is no better. She speaks two languages, Turkish and English, so most of the time she does a half and half randomized mix so nothing makes sense in either language which she seems to not notice the problem at all. :confused:
shortbus
Joined Sep 30, 2009
10,049
I guess I'm real lucky, after being divorced for 30+ years I got my keeper back. Too bad I didn't know then what I know now.
