Hello Max.I could probably come up with the Gerbers, but would need to have a copy of the sensor circuit you have if you want to incorporate it.
Or, By sensor do you mean you intend to use the pre-built board and just add the new one based in the drawing in the OP?
Re: "One board only. Sensor will be added seperate just as an attachment to other board " seems like a contradiction, is it one board or two??
Good morning, Please find attached Sensor Circuit and Resistance circuit.
Please ignore that contradictory line, i was intended to write something and ended up with something which caused confusion. It will be one board with one main design. Individual parts will be added/attached on PCB.
Jay
